90 Accord EX Shift Cable Replacement
Old Aug 6, 2010 | 08:35 AM
mcwulf30's Avatar
Default 90 Accord EX Shift Cable Replacement
Ok folks........am I gonna have to tear into the transaxle to replace this shift cable?
Old Aug 6, 2010 | 12:32 PM
fastshift's Avatar
Default Re: 90 Accord EX Shift Cable Replacement
no. you just need to undo the cotter pins, unbolt the shifter cable bracket on the tranny, undo 2 bolts on the rear sub frame (if it is bolted down there), 2 behind the heat shield, and 2 c-clips on the shifter assembly. I think accords from 90-2002? or 90-97 have the exact same style with minor differences so that should be about right.
Old Aug 6, 2010 | 09:22 PM
joe_accord23's Avatar
wut fastshift said! haha
Old Aug 8, 2010 | 08:18 PM
mcwulf30's Avatar
Thanks!!!
Err.......OH OH!!!
Have D1-neutral............Reverse and park not working.....grinding for both....but not going into park or reverse.
Is my trans out?
Old Aug 15, 2010 | 03:18 AM
Originally Posted by mcwulf30
Thanks!!!
Err.......OH OH!!!
Is my trans out?
check ur fluid, if u havnt changed it den change it...also if it isnt that then u will need to rebuild that tranny or get another one.
Old Aug 17, 2010 | 08:24 PM
mcwulf30's Avatar
danka...
xiris2
Aug 3, 2014 03:36 AM
all_motor_mike
Jan 23, 2013 06:08 PM
Blacksheep0272
Mar 8, 2010 08:35 AM
1stgenboost
Honda Civic (2001 - 2005)
Mar 3, 2009 03:10 PM
HONDA4LIFE
Jun 18, 2002 09:10 PM
