Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cusco LSD what fluid?
Old Aug 6, 2010 | 07:34 AM
soupE__'s Avatar
Default Cusco LSD what fluid?
Is redline mtf 90 fine to put in my transmission with a cusco lsd? I didnt buy the lsd so im not sure what was told to put in it?
Old Aug 6, 2010 | 09:27 AM
El_Capitan's Avatar
Default Re: Cusco LSD what fluid?
Is it a metal plate style LSD? If it is that mtf 90 may work but the diff might be noisy.. In mine I run Motul FFcomp works great when the tranny is warmed up, but its clunky when it's cold.. Torco makes some that is classified GL6 and I wanny try it next oil change -plus its a lot cheaper than the Motul fluid..
Old Aug 6, 2010 | 11:00 AM
soupE__'s Avatar
i just talked to the previous owner i guess hmotors told him to run a 80 weight gear oil.
Old Aug 7, 2010 | 12:09 AM
MFactory's Avatar
Run a good MTF (Torco, Amsoil, GM, Redline etc) and add some Type-F (Ford) friction modifier.
Do not run the Cusco Gear Oil, or any Gear Oil for that matter.
^AnDre^
Nov 10, 2005 09:31 AM
importboi22
Aug 3, 2003 10:20 PM
-DC2-
Jun 2, 2003 06:08 AM
satan_srv
Oct 8, 2002 12:57 PM
