Wheel Backspacing / Offset
Old Sep 16, 2002 | 05:28 PM
PressurizedSi's Avatar
Default Wheel Backspacing / Offset
Ok, I get a little confused on wheel offset.
Example: 99 civic si
+40mm offset vs. +35mm offset.
Which wheel will tuck in closer under the fender? I say, higher the number, the more it tucks inside. Correct? Or is the other way around?
Old Sep 16, 2002 | 05:56 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Wheel Backspacing / Offset (PressurizedSi)
read this
+40 will tuck moer under the lip, actually +35 will probably need the lip either rolled or cut, as in my case with +35 wheels and 2.5" drop.
stan
Old Sep 16, 2002 | 06:28 PM
Default Re: Wheel Backspacing / Offset (90crxsi)
I'm runnning +40's now but I want to tuck them in a little more. I should look for some +42-45's then.
[Modified by PressurizedSi, 5:03 AM 9/18/2002]
Old Sep 17, 2002 | 08:04 PM
Bump. Can some verfiy this please.
morrow921
Sep 15, 2011 02:31 PM
Awsom-o 4000
Suspension & Brakes
Apr 19, 2009 12:45 PM
F20Cdriver
Oct 13, 2008 08:16 PM
Yogi bear
Jun 29, 2001 08:20 PM
