MSD SCI,BLOX CAMS,SYNAPSE 50MM, CATCH CAN SETUP!
All parts were used for 1 dyno session 0 street miles and unfortunately i threw a rod through my block.
Go-AutoWorks B series block fittings,fcsfab catchcan,vented valve cover, all lines and fittings. The lines are -10an 2 off the block 2 off the valve cover price is 380 shipped and paypaled!-----------SOLD---------
Msd sci,msd ss coil and blaster 2 coil, vision motorsports external cap/wire/rotor button and obd1 gsr dizzy-260 shipped and paypaled!
Synapse 50mm Wastegate with 11lb spring comes with v band clamp-200 shipped and paypaled. Has small spot i sanded down to clear radiator support
Skunk 2 Tuner Cam Gears- 110 shipped and paypaled
4 Inch 90 Silicone Coupler 30 shipped and paypaled
Msd sci,msd ss coil and blaster 2 coil, vision motorsports external cap/wire/rotor button and obd1 gsr dizzy-240 shipped and paypaled!
Synapse 50mm Wastegate with 11lb spring comes with v band clamp-180 shipped and paypaled. Has small spot i sanded down to clear radiator support
Skunk 2 Tuner Cam Gears- 100 shipped and paypaled
