clutch chatter with refaced flywheel?
Old Aug 4, 2010 | 11:34 PM
an2ny888's Avatar
Default clutch chatter with refaced flywheel?
i've been hearing this weird sound lately, happens when i'm in reverse or first gear, essentialy whenever your stepping halfway on the clutch, also when im in 5th gear ( gunning it from lower rpms or deccelerating in gear). it also happens when at a stop, you step on the brakes then slowly let out the clutch in first gear, while still being on the brakes. so i pulled my tranny, refaced my exedy flywheel and replaced the clutch disc (FCC). so after all that the noise is still there, is this clutch chatter noise normal?
Old Aug 5, 2010 | 08:06 AM
Dr. DC2's Avatar
Default Re: clutch chatter with refaced flywheel?
I have the same noise. I am not running the transmission "plate baffle" cover. Its the little peice that covers part of the transmission housing. (next to the oil pan) I cannot run this plate because my header (SMSP) runners are 4 across (0000) instead of stacked (88). the header wont fit preperly with the plate on. I beleive thats why my flywheel/tranny is so noisy. Are you running this "plate baffle." If not I've been told that a B16 plate baffle will work (for header clearance) because its a thin sheet metal baffle unlike the B18c baffle which is cast.
Old Aug 5, 2010 | 04:13 PM
itr1244's Avatar
throwout bearing?
loose pressure plate bolts?
Old Aug 6, 2010 | 10:44 PM
an2ny888's Avatar
i replaced the throwout bearing and torqued the pp bolts, so i don't think thats the problem
dannysolis92005
Jul 21, 2009 09:43 AM
fast93accord
Jun 21, 2005 07:17 AM
d_mina
Feb 3, 2005 12:06 PM
People_Mover
Mar 16, 2003 12:42 PM
