'90 Civic Si, need info on the brake system.
Just picked up a 1990 Civic Si hatchback, 5spd/d16a6. I need to know what size master cylinder and booster these have, and what prop valve these have.
I already plan to do the rear-disc conversion using parts from a non-abs DA. I may have access to a prop valve and booster from both abs and non-abs DAs. Just don't know what I should upgrade, or what I can mix-and-match. The mc on this civic is shot, which brought me to this point. Figured now would be a good time to consider upgrading stuff if possible.
i believe they have 20/40 prop valves.. id use non abs parts. a 15/16 mc and 40/40 prop valve from the da. also the bigger mc isnt really nessacary unless you upgrade to bigger front brakes such as ones from the teg. i just swapped prop valves on my 90 dx hatch. i have rear discs from a 99 teg.
95civic_ls_vtec
Jun 16, 2010 02:13 PM
Tbindas
Jun 8, 2005 08:30 PM
B16Jacques
May 6, 2005 12:43 PM
