Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 Civic LX SRS DTC code 2-7
Old Aug 4, 2010 | 08:57 PM
blerim's Avatar
Default 2008 Civic LX SRS DTC code 2-7
The following driver side srs components were activated and replaced: side air-bag curtain, side air-bag (seat), seat belt tongue set, side impact sensor (rear). SRS module was reset and crash data removed. SRS warning light still came on. Reset SRS light, and it goes off, but comes back on. Jumped the 4 and 9 pin of the ODB-II connector and SRS warning light flashes 2-7. That is, I turn ignition to position 2, SRS light comes on for 6 sec, then off for 2, then flashes 2 long flashes, then a pause, then 7 short flashes. This sequence of 2 long 7 short then repeats. The SRS DTC tables I can find don't show a 2-7 code. Am I reading the SRS codes incorrectly? Or, do I need a specific SRS DTC table to get a description of the code? Thanks in advance.
Old Aug 5, 2010 | 05:34 PM
vladd's Avatar
Default Re: 2008 Civic LX SRS DTC code 2-7
what exactly is the 'seat belt tonque set'? does that include both the seatbelt and buckle? also, the srs control module needs to be replaced any time airbags are deployed.
Old Dec 10, 2010 | 01:50 PM
gr8icu's Avatar
I am having a similar problem on my 06. After my car went into a ditch, I had to replace drivers side airbags and module, but I still have this 2-7 code. I took it to the dealer a three times with no success(they told me to replace seat belt which i already have, nonetheless i did it again and nothing changed). I also replaced the module 3 times, in other words i have spent a fortune to get this fixed(i am now out of warranty). let me know if you found the solution.
Old Dec 11, 2010 | 07:11 AM
gr8icu's Avatar
last night i decided to check the resistance in all of my srs components and when i got to the buckle(in the seat) there was no resistance(it should have been about 2.0-2.2 ohm)!!! i cant believe my dealer couldn't tell me this. Be cautious of junk yard parts. blerim, thanks for the pm, i suppose you came to the same conclusion before i did. i wish i came across you earlier that way i wouldn't of had a need to take my car apart, to check it all. thanks anyway.
Old Dec 12, 2010 | 10:23 PM
blerim's Avatar
did you ever get your car to work i had a buddy that worked at honda that my dad knows and he told me just to change the buskle it is code 27-10 that is what it comes up when they read it mmy dads friend just changed the buckle under waranty and i gave him $100
Old Mar 19, 2011 | 08:02 AM
paulb3456's Avatar
Does anyone know what SRS code 2-7 means? I did not see a definition of SRS 2-7 code in this thread.
deanwashere
Jul 25, 2018 04:28 AM
CantWorkonCars
Dec 8, 2017 03:23 PM
Reaccion
24
Oct 20, 2017 11:26 AM
oandroido
Dec 11, 2016 03:17 AM
lv6l
Honda Civic (2001 - 2005)
Oct 27, 2006 08:13 PM
