Failed brakes
Old Aug 4, 2010 | 02:56 PM
Champman's Avatar
Default Failed brakes
I have a '99, non-ABS accord. I was driving today, everything was going fine... the 3rd time I tried to stop, it wouldnt. The brake would go all the way to the floor, probably only 10% braking power to the wheels. It felt like I was sliding on ice. I dont see any leaking fluids (though its raining and I might not see it). The pads/rotors are fine, I also dont hear any abnormal noises.
Is this a common issue? I'm hoping I can diagnose it before I take it into a shop.
Old Aug 4, 2010 | 02:59 PM
PTV6's Avatar
Default Re: Failed brakes
Sounds like you have air in the system.
Old Aug 4, 2010 | 03:06 PM
chikin pickle's Avatar
There are places that fluid will leak and you may no see it. If you have drum brakes for example. IT could be a failed seal in there, possibly a caliper piston seal, or air in the system. However air means you have a leak if they were working before and you haven't opened up the system.
Another problem is if the piston seals fail in the master cylinder then fluid will leak back and forth rather than pressurize the hydraulic system.
Old Aug 4, 2010 | 03:59 PM
Champman's Avatar
Just an update, I added some fluid and it is leaking about 2 feet in front of the left rear wheel. Cant really see anything, hoping its just a hose.
Old Aug 5, 2010 | 06:58 AM
jdadams12's Avatar
Probably a hose or a metal line. If you replace it, you will need to bleed all 4 wheels just to be sure that there is no air.
avaldez
Jul 17, 2009 11:29 AM
Bruce Banner
Jun 11, 2007 11:39 AM
AznPrideYo
Aug 26, 2006 12:00 PM
grenthang
11
Nov 15, 2004 09:08 PM
reddigitaldragon
May 13, 2003 10:38 AM
