B16 Injector Missing
Old Aug 4, 2010 | 01:18 PM
EFjoe91's Avatar
Default B16 Injector Missing
Ok so if you check my other posts you know what is going on.
This is where iam. Ecu cooked, got new one. Got wires all check out. everything was Ok. So i am now getting a mis fire. Indicated it was the distributor. HAD back up- Back up didnt fix.. I am still throwing same ECU code #9 before my ecu shorted. So i replaced ECU and NEW dist. And same cyp cylinder position sensor light.
That is ne concern. My other is that the Misfire is the Injector #3. I am not getting power or voltage. I dont know how to further diagnose
Car runs now, Dead cylinder #3 Do have spark, Fuel isnt in the cylinder injector clip wire is not conductive. Checked it at the ECU and left off becase i dont know what i am doing or what to do I am at the point where im again afraid of a short or another Failure. Please imput Thanks JOEE
Old Aug 4, 2010 | 02:45 PM
frank_el_tanke's Avatar
Default Re: B16 Injector Missing
run wire from ecu for inj. #3 n ground the wire with the rest of the injectors. google is ur friend.
Old Aug 4, 2010 | 03:38 PM
EFjoe91's Avatar
I dont like doing things that way, But thanks for the input.
Spent many many hours out there. Finally After a Clear month on the calander i figured it out.
Injector 3 wire blue was half *** solderd. Touched it when i located it and it basically broke. Connection was slim to none. Not sure if that caused the ECU to wipe out But it was a intermitten signal that was disturbed. I still have the ENGINE LIGHT blinking 9 times. Cyp. Sensor Still cant FIX the thing.
Old Aug 6, 2010 | 12:43 AM
dohc4life's Avatar
welll since its an ef and you say misfire, the 2 blue wires ones blue green ones blue yellow if those are backwards your car will missfire backfires sometimes wont run
Old Aug 6, 2010 | 11:04 AM
EFjoe91's Avatar
THE CONNECTOR AT ECU WAS BAD. 1 month of NIGHT MARE
FINALLY GOT FIXED. STILL THROWING CODE 9 OBD1
CANT GET THE CODE TO CLEAR EVEN THO I HAVE NEW DIST AND ECU.
salemned
Sep 7, 2017 12:13 PM
Nt03hamlin
Classic Hondas
Mar 22, 2011 06:17 PM
TwoKSiR
Sep 23, 2010 06:09 PM
TwoKSiR
Sep 14, 2010 03:25 PM
underpressure02
Apr 7, 2007 05:10 AM
