F/S- Fully Built B18C w/ ITB's...maybe part out. Make offers
I have my FULLY BUILT B18C motor for sale. Getting out of scene. Recently pulled motor from EG and is ready for pick up. I have video of it running just a couple months ago. PLEASE NOTE the motor is LOCATED in Elk Grove 5 mins south of Sacramento
The motor was a COMPLETE build. Has about 3000 miles on it
MOTOR was built and tuned by Elton Lo of RACELINE DEVELOPMENT in Temple City, Ca. If you don't know much about RACELINE or Elton you can do you research and find that he is one of the most well known and respected shop owners in California
Chris (916) 870-1022
NO TRADES!
CASH ONLY!!
IF your interested in a BIG part i.e TRANNY, LONG BLOCK, ITB set up then make me an offer 'IF' its decent I may consider it!
Now for the details...
Motor DYNOED at 238 hp with the DYNO only registering up to 7300 RPM
B18 was bored to 2.0 L w/ 12.1 Compression
BLOCK
Eagle Rods
Eagle Pistons 85mm
Type R Crank
HEAD
TYPE R Head with light PORT and POLISH job done by Elton at Raceline
Super Tech Valves
TODA retainers
TODA Valave spring
TODA Cams (B's)
TODA Timing Belt
TODA Cam Gears
ITB's
TWM 45MM itbs
RC 550cc injectors
TRANNY
S80 Type R w/ LSD
ACT Stage 3 Clutch
TODA Lightweight FLY WHEEL
ECU
APEXi Power FC w/ Commander
Others
OIL Filter Relocater
CTR Pulley
SPOON OIL Drain Plug
NO TRADES!
CASH ONLY!!
BLOCK
Eagle Rods
Eagle Pistons 85mm
Type R Crank
HEAD
Super Tech Valves
TODA retainers
TODA Valave spring
TODA Cams (B's)
TODA Timing Belt
TODA Cam Gears
ITB's
TWM 45MM itbs
RC 550cc injectors
TRANNY
S80 Type R w/ LSD
ACT Stage 3 Clutch
ECU
Others
CTR Pulley
freakie
May 14, 2004 12:25 AM
