94 accord shifting problems
hello HT
my buddie has a 94 lx accord 4 banger.
when the car is cold it shifts fine, but when its warm... the 3-4 shift takes forever and then it bangs into gear. no check eng lights,
what cuold cause this long and then rough shift from 3-4gear?
thanks HT
thanks HT
The fluid is likely losing viscosity when it gets hot.
Change out the fluid 2 times using Honda Z1 ATF. Drive it 10-15 minutes in-between each change. Notice the amount of junk on the magnetic plug, if it has one.
My 92 takes 2.5Q each drain and refill, but check your manual for your 94.
EvanR
Jul 12, 2015 07:51 AM
76 camaro car
Jan 1, 2014 06:37 PM
skiptomylou
Mar 4, 2006 02:08 PM
