CRX HF JDM d15 wont start :(
Old Aug 3, 2010 | 11:33 AM
JDM_stephen's Avatar
Default CRX HF JDM d15 wont start :(
I was driving my crx sometime last week just cruising hadn't ran it hard or anything an stopped to get gas, after getting gas it would start and immediatley cut off, it done this several times then finally started, later that day i went to go pick up a friend and it cut off pulling in the neighborhood, same thing again, finnaly after getting started and getting friend i get home and it cuts off while idling. Now it just does the whole start then immidiatley cut off deal over and over and makes a bogging sound and then cuts off if i give it gas and try to start. Im going to drop the gas tank soon and look at the fuel pump anyone got any advice to maybe what it is thats wrong with it? i love my crx and ive only had it for a month its my first honda
Old Aug 3, 2010 | 05:40 PM
khellapeter's Avatar
Default Re: CRX HF JDM d15 wont start :(
hey you dont need to drop the gas tank to check the fuel pump! all you got to do is take of the rear compartments in the car and the fuel pump is right there. also check to make sure your main relay is good and doesnt smell burnt... main relay is up buy the clutch pedal.... and also try checking the ect sensor its a 2 wire plug right under the distributor goood luck!
pdx_503
Oct 4, 2007 11:55 AM
coilback
Oct 12, 2006 06:19 AM
Yamaha798
Apr 5, 2005 08:43 AM
dunkd
Nov 17, 2004 05:57 PM
garagespecial
Jun 25, 2002 10:00 AM
