Help...Fuel Filter.
Old Sep 16, 2002 | 03:06 PM
Art Vandeleigh's Avatar
Default Help...Fuel Filter.
i have a 6th gen-2001 accord, i was llookign for the fuel filter but i could not find the damn thing....it should be real close to the firewall and the fuel rail right??? but i cant seem to find it. can some one shed some light on this. thanks!!!
Old Sep 16, 2002 | 03:08 PM
Brandon's Avatar
Life is Suffering
Default Re: Help...Fuel Filter. (up-youRs)
It is on the gas tank. Which you have to drop out of the car to get to.
Old Sep 16, 2002 | 03:17 PM
Default Re: Help...Fuel Filter. (B the Turbo Pimp)
ohhhh god.....now that just put a damper on my day
Old Sep 16, 2002 | 03:21 PM
ohhh man i just want to bitch about this........why do they have to be some damn complicated!!!!! its not hard i know...but just some damned unnecessaryly tedious!!!!!!!!! just to change a stupid fuel filter. sorry...delete if you wish.
Old Sep 16, 2002 | 03:22 PM
allaboutaccordz's Avatar
is it the same placement on all accords? i have a 1990 (4th gen). where is it on my car?
Old Sep 16, 2002 | 03:28 PM
Default Re: Help...Fuel Filter. (allaboutaccordz)
i am not sure but if you look in the engine bay and if you dont see a tubular item on the firewall or see anything like that close to or connect to the fuelrail, then you probably have the same as mine. according to B the Turbo Pimp, the fuel filter is next to the gas tank..... honda
Old Sep 16, 2002 | 03:40 PM
YodiBrodi's Avatar
thankfully for you guy(dude w/ the 4th gen) yours is right on the firewall
look at you fuel rail on the end toward the passenger. there will be a metal tube that heads back toward the firewall and under some black plastic box that i can't remember what it is and down. your fuel filter is back there directly bolted to the firewall. you will have to remove that box to get to it.
Old Sep 16, 2002 | 03:42 PM
GimpyAccord's Avatar
Default Re: Help...Fuel Filter. (YodiBrodi)
thats your MAP sensor, egr vacuum solenoid amounst a few other things
Old Sep 16, 2002 | 03:43 PM
easy to replace? mine is still factory (90k on it) and im going to be running nitrous soon, so i wanna replace all the fuel componets
Old Sep 16, 2002 | 03:47 PM
yah its easy to do. my advice to you is pull the fuse to the fuel pump, start the car and let it die (kills pressure in the line) and then swap it out. never fear.. some fuel will leak though but thats normal.
Old Sep 16, 2002 | 04:17 PM
Chiovnidca's Avatar
Take it easy. It's not that big a deal. It's not neccessary to replace it unless there is a problem with it. (Like most Honda's from "95" to present.)
nico260488
Dec 12, 2013 01:33 PM
creator1322
Aug 31, 2008 01:34 AM
A Tribe Called Honda
Mar 30, 2007 05:28 PM
speedaccordinly
Apr 25, 2003 03:39 PM
