Honda CR-V & Element 2WD & 4WD Element & CR-V
04 CRV brake light bulb burnt out... or not?
Old Aug 2, 2010 | 03:06 PM
stranskydesign's Avatar
Default 04 CRV brake light bulb burnt out... or not?
The left rear brake bulb is out when I hit the brake pedal but it flashes when I use my keychain to unlock the car. What gives? Expensive electrical issue or simple loose connector? Thanks.
Old Aug 2, 2010 | 03:37 PM
Targa250R's Avatar
be professional
Default Re: 04 CRV brake light bulb burnt out... or not?
It's a 2057 dual-filament bulb - one filament is used for the brake lamp, and the other filament is used for the parking lamp.
It's pretty common to only have one bad filament in a dual-filament bulb.
A bulb costs $1 and takes less than 5 minutes to replace. You're thinking way too far into this instead of approaching it with the simplest solution first.
Old Aug 3, 2010 | 05:55 AM
I didn't see much point in changing the bulb if it still lit in one condition. I wasn't aware of the dual-filament, hence why I posted here. Thanks for your very helpful albeit kurt response.
barfo
Feb 8, 2015 04:12 PM
SCinCA
Oct 6, 2014 06:35 PM
professorman
Oct 27, 2013 06:28 AM
Mishako129
Jun 4, 2013 10:50 AM
951dc5
Nov 18, 2004 02:42 PM
