Spec clutch r junk dont buy one
spec clutches are junk and cant hold no power. i brought a stage 5 for h22 and the thing slipped in less than 300 miles. then spec dont want to back there product. oh yeah and then spec tells me they "misprinted" there power ratings. so a stage 5 cant even handle 350 ft pounds and it was suppose to handle 599 ft pounds. so anyone that makes any power wouldnt get a spec clutch there Junk
Also, to say that we don't back our products is incorrect as well. If you are having a problem with the clutch slipping due to an incorrect rating on the web site, contact us and we will be glad to help you.
and on a side note. before you want to come in here and start jumping on any ones case. did you even check to make sure your motor was properly set up before installing this unit? was your flywheel in good useable condition? what about your seals? how did it get installed? by you or another indivisual? was there oil on it before it got installed? what about your transmission? are/was there any cracks in the casing to make it leak fluid onto the clutch before/after you installed it?
process of elimination if your friend before you go rampaging about some one elses mistake before you even checked up on your own mistakes
