NC FS/FT:1991 Civic SI**SHAVED&TUCKED/B16A/D2/ITR/BREMBO/DSS/CC/HONDATA**
Old Aug 2, 2010 | 07:00 AM
watisjdm's Avatar
Icon3 FS/FT:1991 Civic SI**SHAVED&TUCKED/B16A/D2/ITR/BREMBO/DSS/CC/HONDATA**
Contact: PM or text 919-218-0546
Price: $3500 obo/ Trade for 92-95 EG hatch(stock or some modded), 96-00 EK hatch or really anything but ^^ are the ones id rather trade
Title: Clear in Hand
The Good: FAST,Shaved and tucked engine bay, a good amount of money into, heat still works lol, si, sunroof, bodywork done, Brand New D2 Coilovers, no leaks and doesnt burn a bit of oil!!!
The Bad: Flat Black, Loud, Exhaust rattles, 3rd Gear grind at high rpms,no a/c, stripped interior
WILL GET UP TO DATE PICS SOON!!!!!!
Car now has Brand New Tires up front on 14" steelies
Also has 4 brand new ARP wheel studs on passenger side
NO TRADES NOW, NEED CASH!!!!!!!
Car will run Low 9's High 8's in the 1/8 with better suspension and slicks!!!!!!! I ran mid 9's spinning on 13" tires lol with the cut springs
Car ran a 14.9 at 97mph in the 1/4th that trap speed people normally run about a 14.0 or so, also fresh oil change with 10w-30 Royal Purple
Mods:
Exterior:
-JDM Yellow Foglights
-Nokya 4300K High Beam & Low Beam Bulbs(Brand New)
-Window Visors(Not Installed)
-Rolled & Cut fenders
-Rear wiper Delete
-Amber Corners
-88 Doors(painted flat black)
-OEM SI Front Lip
-OEM Mudguards
Suspension:
-Brand New D2 Coilovers (maybe 300 miles on them)
-Front And Rear Strut Bars
-Roll Cage(welded in)
-OEM Swaybars
-Brembo Drilled and Slotted Rotors(all the way around)
-Hawk Pads'
-New lower front ball joints
Interior:
Not much there lol
-Grant 330mm Steering wheel
-Type R replica Shift ****
-4 Point Racing Harness
-6pt Roll Cage
-Battery relocated in rear
-Brand new shurokien battery and terminals
Engine management:
-Chipped PWO
Motor: JDM B16a OBD0 (47k)
-JDM ITR HEADER
-JDM ITR Intake Manifold
-JDM ITR Valvetrain
-JDM ITR Camshafts
-JDM ITR Throttle Body
-Hondata Intake Manifold Gasket
-Hasport Shift Linkage
-Innovative Steel Mounts
-Ebay Short shifter
-Full 2.5" Exhaust
-All New Tune up
-New OEM Headgasket
-NEW OEM Timing Belt
-New OEM Water Pump
-New OEM Cam Seal
-New OEM Valve Cover Gasket
-New Spark Plugs
-New PHAT WIRES LOL
-New Radiator Hoses
-New Fuel Filter
-New Walbaro 255 Fuel pump
Transmission: XSi Transmission W/LSD
-CC Stage 3 Clutch
-7.5lbs Flywheel
-DSS Stage 2 Axles
I know there is more if I can think of it
Old Aug 2, 2010 | 07:14 PM
srt4mike's Avatar
Default Re: FS/FT:1991 Civic SI**SHAVED&TUCKED/B16A/D2/ITR/BREMBO/DSS/CC/HONDATA**
Bump for viewing.
Old Aug 3, 2010 | 06:32 AM
watisjdm's Avatar
thanks man, upppp
Old Aug 4, 2010 | 07:27 AM
watisjdm's Avatar
bumpppp
Old Aug 5, 2010 | 06:33 AM
watisjdm's Avatar
bump for strong vtecc
watisjdm
May 24, 2010 01:58 PM
watisjdm
Apr 8, 2010 06:02 AM
hamizle
Aug 6, 2009 03:42 PM
PotatoePAPA
Mar 4, 2006 09:37 PM
