How to do remote start w/ Viper 5701
Hello everyone
I will be installing an alarm on a automatic 1997 integra.
I have done an alarm installation before and can locate all the wires needed.
I would like to install remote start on my wife's vehicles. If anyone can explain to me which wires I will need to locate and connect I would greatly appreciate it
Thank You
Thank You
Use the link to find the connections for the Integra
http://www.the12volt.com/installbay/...etail/162.html
HEAVY GAUGE 10-pin CONNECTOR:
Connect (H3/1 Pink) to Ignition wire of car
Connect (H3/2 Red/White) to constant 12v Wire of car
Connect (H3/3 Orange) to Accessory Wire of car
**Note: You will have to cut the starter wire to connect H3/4 and H3/5
Connect (H3/4 Violet) to the car side of the starter wire
Connect (H3/5 Green) to the key side of the starter wire
Connect (H3/6 Red) to constant 12v wire of car
(H3/7 Pink/White) not used
(H3/8 Pink/black) not Used
Connect (H3/9 Red/Black) to constant 12v wire of car
REMOTE START INPUT - 5-pin CONNECTOR:
Connect (Black/White Neutral safety switch) to the ground wire of the handbrake
Connect (Violet/White Tachometer Input wire) to the car's tach wire (You can find the tach wire behind the cluster or in the engine bay
connect (Brown Brake Shutdown Wire) to the car's brake wire
Connect (Gray Hood pin wire) to the hood pin (must install the supplied hood pin for this)
(Blue/White Status/Defogger) not used
Remote Start Auxiliary Output 5-pin connector: Not Used
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Also make sure that you plug in the switch on the alarm brain and make sure its in the on position. Or the alarm will not remote start.
I have a viper 5701 remote start.
I havent and dont want the remote start so i installed everything else. plus only the pink wire to the ignition.
My problem is that if i run the car then turn it off and remove the key. and try to arm the alarm . it wont. the remote wont responde. I check with a test light and check the pink wire and the alarm clicks inside. after that i am able to arm/disarm the alarm. I feel the alarm continues to receive the ignition messege and dosent allow me to do anything with it.
Thanks for the help.
dreams_of_ek9
Aug 27, 2008 05:56 PM
TurBoXBirD16
Audio / Security / Video
Feb 26, 2002 03:12 AM
