Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
'96(?) Odyssey MPJA gear ratios.
Old Aug 1, 2010 | 04:56 PM
MAD_MIKE's Avatar
MM Gruppe B
Default '96(?) Odyssey MPJA gear ratios.
Would anyone happen to know the gear ratios and final drive in an MPJA automatic? I found F/H Series Gear Ratios in the Accord FAQ.
Just wondering if the Odyssey shared the same gear ratios and just had a lower FD like the Accord Wagon, or if its lower geared(overall) like some of the Prelude automatics.
FWIW I replaced the transmission in a '95 Accord EX with this transmission and am wondering if mileage will be affected by the new transmission. T.I.A.
Old Aug 15, 2010 | 04:26 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: '96(?) Odyssey MPJA gear ratios.
What rpm does the engine turn at 70MPH in OD in the First gen Odyssey? Thanks
Old Oct 24, 2010 | 08:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Torque Converter Stall speed?
Would anyone happen to know what the stall speed is on this same transmission torque converter? I had to change out the flexplate on the F22B1 to match the larger converter from the Odyssey. The old trans had a ~9-3/8" TC and the Ody unit is ~9 7/8" whatever that is in metric speak.
Old Oct 28, 2010 | 10:37 AM
evil_ryu's Avatar
i dont know if this helps?
Old Oct 31, 2010 | 09:15 PM
MAD_MIKE's Avatar
MM Gruppe B
Actually it does.
New 2650 stall
Limit 2500-2800 stall
Thanks evil_ryu! Now I just need to find the similar for the Accord.
Old Feb 21, 2011 | 02:14 AM
MAD_MIKE's Avatar
MM Gruppe B
FWIW it appears the MPJA does share the gear ratios of the Si Prelude AT.
USDM H23A1 92-96 PRELUDE Si COUPE:
Diff Type & Tranny Codes:
STD Only = ?
2.705 1
1.535 2
1.057 3
0.750 4
4.428 final
4th gear 195/60 R15
70mph = 3227 rpm
80mph = 3688 rpm
firozilahi
Dec 16, 2017 03:15 AM
