Relocate Washer Fluid ? Or Buy smaller tank?
Old Aug 1, 2010 | 02:15 PM
wtsapexipowerfc's Avatar
Default Relocate Washer Fluid ? Or Buy smaller tank?
Just wanted to know what my options are.
It seems to me that I have to relocate my washer fluid bottle, to fit the U bend pipe to meet my intercooler....
What is the easiest solution? Are there any DIY ? or Smaller washer fluid bottles? vertically small
Old Aug 1, 2010 | 03:17 PM
bouncecrx's Avatar
Default Re: Relocate Washer Fluid ? Or Buy smaller tank?
homemade DIY lol
take the oem tank , remove pumps and seals ( o-ring mounted on tank )
cut the bottom of the tank ( enough to clear your charge pipe)
now you need to drill hole(s) for the new pumps
measure oe hole diameter, drill hole of the same diameter at approx 1/2 inch of your new bottom. put the seal on the new hole(s) .
new bottom fab. i used the black plastic shield that mounted deside the radiator.
or any piece of plastic large enough to match the tank
cut, trim to fit, hotglued. (epoxy could work great too )
taddam
check for leaks
fluid capacity is now approx. 1.5 liters
Old Aug 2, 2010 | 04:03 PM
anyone have a DIU for moving it to the back ?
jasonjai
Sep 9, 2011 06:14 AM
HondaHeddie
Apr 24, 2008 02:30 PM
Thunder Cat
Dec 9, 2005 03:39 AM
GroundZer0 336
Aug 3, 2003 09:44 AM
