s2k rim qustion
i found a good deal on a set of s2k ap1 rims the rears are 16x7 1/2 and its wide just wnna know if any of ya try this yet .will it fit ok or do i need to find 2more front or some little mod will make it work.thanks
all rims size should be the same .. no staggered set!
coz youll have issue w/ your 4wd.. i saw one V owner here
used a staggered set but he did have the same tire size in
all 4 rims.. idk what happened or if its still good...!?!?!
but if your crv is a 2wd one.. yes you could use a staggered set!!
you might wanna try to install same size of tires in all rims,
then observe, idk if you'll have isues w/ the rt4wd system
but i said, one V owner did the same way, you might wanna
back read... i aw his post here before...
good luck!!!
good luck!!!
hondatuner208
12
Mar 19, 2008 09:22 AM
