nos...questions
Old Sep 16, 2002 | 01:17 PM
drunk's Avatar
Default nos...questions
hey guys...i told you i was getting nos...well i am getting it installed tonite..i am kinda scared...on putting it on the zc....i am doing a 50 shot...it is just the fact i dont want to blow the motor ......how long have u guys sprayed on your zc's? i am not going to spray light to light.....just when trying to race a mustang....or a track nite.....what would u say bout it?
Old Sep 16, 2002 | 01:23 PM
zcivic91's Avatar
Default Re: nos...questions (drunk)
well i got my zex on this weekend..it pulls nicley..but havent been able to use it for more than 1 gear cuz my tps is fucked up..
maybe i can killl 2birds wit 1 stone..maybe the new tps will fix my hesitating and the wot problem wit my zex..
oh....if anyones got a tps laying round ill take it!!!!!!
zcivic91's Avatar
Default Re: nos...questions (zcivic91)
run the colder plugs, retard the timing when using n2o
Old Sep 16, 2002 | 03:12 PM
USDM 4G VTEC's Avatar
ur ZC will be able to handle the 50 shot with no problems.... just make sure u retard timing a little and usde cold plugs....dont run that thing to hard,,,,, dont overspray.... just spray every weekend or something..... and as xperience on this **** i recomend u to spray only on 1st, 2nd and 3rd.... dont do 4th and 5th since u might melt valves, like it happen to a A6 my cousin owned...
Old Sep 16, 2002 | 03:20 PM
SOUTHCREX's Avatar
Default Re: nos...questions (JDM EF9)
Yup I would be careful ZC's are not very N20 worthy, now a sohc vtec will pretty much take all the abuse you can give it with juice. 20 seconeds squeezing with a 75
Old Sep 16, 2002 | 03:24 PM
Default Re: nos...questions (TEAM GARAGE SHIFTDOWN)
SOHC VTEC (Z6) 9:2.1 CR good for turbo and N2O
ZC 9:6.1 CR not that great but still good since its on the 9's
SOHC VTEC (Y8's, Z7's etc...) 9:6.1 CR wich its same as ZC
always remember the lower the compresion the best or better said the more suitable the engine its for N20 or Boost....
Old Sep 16, 2002 | 03:57 PM
SOUTHCREX's Avatar
good point, was reffering to z6, never had any expeirance with a y8.
Old Sep 16, 2002 | 07:31 PM
drunk's Avatar
well i got the NOS in the car....it ran BAD ***...i only hit it in 3rd tho....it felt GOOD!...my intake tube keeps comming off. and the bolt broke that held on the silonods???? spelling is SOO off......so i will fix all that in the morning and redo the bottle so it is iin a better place besides behind the passenger seat
Old Sep 16, 2002 | 11:01 PM
88_SC_CRX_Si's Avatar
New User
A high C/R running a "N20" set-up... Soooo, far has proven to work fine. However like mentioned above, it has the oppsite effect on a FI'ed car...
I have some "V8" friends running 150 - 250+ shot on the there H/C/R "engines", were talking 600 to 800 hp here. These peeps are running early to mid full sized Chevy, ect... Pick-ups. That are pulling mid 10's to 11's. I have been to the drags, watched them run, and personally seen their time slips...
Sooo, their engines may be differnet fom ours. However the basic principals remain the same... Just as long as the fuel and ignition system are maintained. There should not be any problems with dentonation... As long as COMMOM SENSE is used...
[Modified by 88_SC_CRX_Si, 12:04 AM 9/17/2002]
XzIpK
May 13, 2007 07:16 PM
JDM H22
Jun 17, 2005 02:54 PM
HotImportNightHonda
Sep 23, 2004 09:43 AM
JTCdudeman
Nov 12, 2003 05:16 PM
sicklexus1
Jan 29, 2003 03:30 PM
