is the poly kit worth it for better et's???
hi, im goin with skunk2 drag springs because i wannna drive it on the street also but i was wondering if the whole poly kit is worth putting in you'r front control arms for better et's someone sayed???
which part number should i buy from enery suspension??
also should i set my camber at 0 or doesnt matter much??
Poly bushings in the front will help to control the wheel hop on take off as well. Rubber will allow more movement during hard launches where as Poly bushings will help to keep everything solid and stable.
0 camber would give you a even distribution on weight on the tires so that can help them hook up better, and as for the bushings i dont think its to hard to remove the old onees if u have a little press at home.
thats whats i thought and people are saying camber kits sucks!! thanx guys
Trumpster
Feb 24, 2005 04:25 PM
Brewer
Feb 8, 2002 05:45 AM
