Welding a JDM T-Bar Dc2
Old Aug 1, 2010 | 07:10 AM
phivrne's Avatar
Default Welding a JDM T-Bar Dc2
Hey guys, so i'm curious to know if anyone can lead me to the right direction of welding the T-Bar on a Dc2.
sorry for the noob question, as i don't have experience welding.
the main concern on mine is the alignment.
and the second is welding.
so pretty much, where i come from, they are willing to charge around $800 for just welding on the t-bar.
ok so all i need to do, is remove the spot welds with a 8mm spot weld remover drill bit, correct ?
then take out the old t-bar, and weld the new one on ?
what placement should the t-bar end go for the jdm one ? would it be in the same place as the old one ?
what kind of welder do i use, details ?
any other hints ?
do i need to put some thing on the t-bar to weld it on prior ?
Old Aug 3, 2010 | 09:32 PM
97ek-t's Avatar
Default Re: Welding a JDM T-Bar Dc2
drill the old t bar out..
put the jdm hood/fenders on and mount the jdm t bar on there is a hole on each of the fenders that hold the t bar where it needs to be welded.
your gonna have to cut some sheet metel off both sides so the t bar can slide in
daitantamashii
Jan 24, 2011 08:53 PM
TRIppinHonDA
Aug 11, 2005 04:20 PM
super_mut
Jul 22, 2005 04:28 AM
