Suspension & Brakes Theory, alignment, spring rates....
PRELUDE - EIBACH PROKIT**# 4008.140
Old Aug 1, 2010 | 07:06 AM
jacksonww's Avatar
Icon2 PRELUDE - EIBACH PROKIT**# 4008.140
Anyone know off hand if 3rd Gen Prelude springs will fit on a CRX?. I'm thinking the only difference would be the drop.
Eibach Part # for CRX is 4007.140. Prelude is 4008.140
Thanks
Old Aug 2, 2010 | 08:36 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: PRELUDE - EIBACH PROKIT**# 4008.140
Different part numbers mean different spring rates and dimensions. why not just buy the correct spring for the car?
The prelude had a b20 engine, which was several hundred pounds heavier than the D-series, so i am sure their spring rates are higher than the crx's rates.. my money is on "if they fit, they will be so stiff you won't have teeth left after the first drive". maybe that's what you are looking for though.
Old Aug 2, 2010 | 09:00 PM
mattliston's Avatar
the prelude b20 was NOT several hundred more
Id **** myself if it was more then 50 pounds over
Ive had to change a few. a CRV b20 is heavier, and certainly not even 100 pounds heavier
Old Aug 2, 2010 | 09:52 PM
hatchet_honda's Avatar
hmm proly wont fit..even if the parts are gonna be free juss forget it and buy the correct parts for a rex
Old Aug 2, 2010 | 10:17 PM
D16SiHatch's Avatar
guess you better check your britches :p
b-series engines on average are about 100lbs heavier than a sohc d-series.
Old Aug 2, 2010 | 10:33 PM
jacksonww's Avatar
You nailed it!. I called Ebach today. Fit is a maybe and the spring rate is double what the correct kit is.
Thanks everyone.
shhh151
Suspension & Brakes
May 18, 2009 01:34 PM
D-meet07
Jul 12, 2007 07:12 PM
b18cx
Jun 7, 2004 06:42 PM
GroundZer0 336
Jan 4, 2004 08:24 AM
