Axle seal Keeps leaking!!
Old Aug 1, 2010 | 03:31 AM
JDM_b20's Avatar
Icon2 Axle seal Keeps leaking!!
I have replaced my passenger side axle In my bseries trans held fine up till a week later, I pulled the axle back off to see the seal was pushed in a little on the bottom I pulled it of ordered a new one for a 94 desol filled it back up with MTF and lsd additive called "ford modifier" held good for about a day came out to my car for work to see a puddle under my car sure enough it was MTF, I Just ordered a new axle for a 91 integra and a seal from a integra, my previous axle was from a 94 desol with abs on it. i have some pictures of it the bottom surface looks like its protruding a little bit but not too sure. Thanks in advance.
Old Aug 1, 2010 | 05:16 AM
elmalouno's Avatar
Default Re: Axle seal Keeps leaking!!
sounds like your on the right track. you want to run DA axles with a DA intermediate shaft in ef chassis. are you using a seal puller to replace the axle seal? why is the lip of the opening so chewed up ?
Old Aug 1, 2010 | 12:33 PM
JDM_b20's Avatar
Lip was chewed up from previous owner. that's what I'm thinking is causing it to leak. I'm using my seal press kit to replace the seal too make sure it sits flesh with the trans.
Old Aug 1, 2010 | 03:24 PM
Jockone's Avatar
Do you have any play in the diff,ie can you move the diff up and down at all?
Bad diff bearings wil cause the seals to leak.
Old Aug 1, 2010 | 03:29 PM
EJ1_Sleeper's Avatar
yea thats a bitch if the lip of the axle hole is chewed i doubt its going to seal at all.
also that bearing looks beat on the diff man.
Old Aug 3, 2010 | 10:47 PM
JDM_b20's Avatar
thanks guys for the input, I finally got it fixed for some reason the axle i got would not seal so it was leaking from the axle going into the seal into the trans, still dont know why two axles i tried wouldn't seal it, ended up getting a Honda axle instead of a auto zone axle, but the problem is fixed thanks again for all the help.
driveslow
19
Mar 5, 2009 07:03 PM
gabebauman
Jan 17, 2006 01:11 PM
14bcoupe
Dec 12, 2004 02:35 PM
Race Egr
Mar 9, 2004 06:14 AM
Brian-Brian
Mar 13, 2003 06:52 PM
