strange "clanking" noise when the engine is under load please help
Old Jul 31, 2010 | 01:53 PM
Ghett0_ed's Avatar
Default strange "clanking" noise when the engine is under load please help
The car is an 89 civic si with the stock a6
This just started happening about three weeks ago. When I'm going up a hill or in a higher gear at a lower speed and try to accelerate I get a strange clinking noise. It dosnt sound like the rattle you would hear if an exhaust shield were lose if sounds like it may be something internal
Like I said it dosnt happen happen unless there's more load on the engine. I.e when in nuetral and I rev it I don't hear the noise.
I searched and couldn't find much except possibly detonation. Does this sound right? And how would I check for it or repair it? Just adjust the timming if needed.
Any info or suggestions would be much appreciated please keep the bs out.
Old Aug 1, 2010 | 03:48 AM
~sp33~'s Avatar
EFB055
Default Re: strange "clanking" noise when the engine is under load please help
Could be pinging if the ignition timing is too advanced. Try retarding it and see if it makes a difference.
Old Sep 4, 2010 | 02:56 PM
sevwen7's Avatar
did this work because im having the same problem but i have a d15b2. and how do you retard the ignition timing?
Old Sep 4, 2010 | 05:57 PM
hondachris1994's Avatar
lossen the distributer and turn it 2 the left that retards the timeing and towards the radiator advances it.
Old Sep 4, 2010 | 06:00 PM
sevwen7's Avatar
ok thanks hondachris
Old Sep 4, 2010 | 11:08 PM
fatCRXguy's Avatar
Check your timing belt. it could need tesion. my hatch was make a similar noise because the timing belt had to much slack.
Old Sep 4, 2010 | 11:21 PM
90dohczccrx's Avatar
could be your valves and springs cause my motor was doin the same thing till i changed the valves and springs in it
Old Sep 5, 2010 | 01:27 PM
DCRB's Avatar
o/p, please post a video. a "strange clinking noise" could be many things.
Old Sep 5, 2010 | 03:08 PM
Ghett0_ed's Avatar
I can't really because like I said it won't make the noise if there is no load on the engine and I'm thinking my car will be to loud to be able to hear it on video but I'll give it a shot...
Thanks for the input guys I don't believe it to be valve ticking it doesn't quite sound like that
I'm going to check the timing here soon I'll keep this updated if I figure it out
Old Sep 5, 2010 | 06:20 PM
90.ef9.hatch's Avatar
could also be spark knock. check the gap on ur plugs/or change them. its happened to me before and iv changed them and it went away. now i run NGK plugs havent had problem for a while now.
Old Sep 5, 2010 | 06:38 PM
mattliston's Avatar
Exhaust if it isnt pinging or detonation
Under load that thing is virbrating quite a bit.
Check your engine mounts. the extra vibration from high load might be causing lots of movement, causing the exhaust noise.
Also, moving exhaust= chance of hitting bottom of shifter in a manual car
ghettogk
Nov 15, 2004 06:38 AM
sstinson
Sep 24, 2004 02:01 PM
BurningDaSuckers
Sep 14, 2002 09:06 PM
93SSPHatch
Jun 4, 2002 09:24 AM
