Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic EM2 Trunk/Gas key latch
Old Jul 31, 2010 | 07:55 AM
Trandana's Avatar
Default Civic EM2 Trunk/Gas key latch
When I put the key in the keyhole by the door it wont turn, its stuck in the open position so I can still fill up gas but I can't use it to pop the trunk Just wondering if anyone knows a quick fix?
Thanks
Old Jul 31, 2010 | 08:33 AM
GriFFIthS's Avatar
Default Re: Civic EM2 Trunk/Gas key latch
https://honda-tech.com/forums/honda-civic-2001-2005-78/trunk-lever-stuck-2808868/
Old Jul 31, 2010 | 09:12 AM
lazlong's Avatar
If the lube doesn't fix it you could try to shim it. http://www.civicforums.com/forums/36...se-issues.html
Old Jul 31, 2010 | 02:17 PM
Trandana's Avatar
sweet, ill try that
thanks
Old Aug 1, 2010 | 01:50 PM
AutoXer's Avatar
PB Blaster worked for one of my stuck lock cylinders. If that doesn't work, you'll have to pull the cylinder and rebuild it or take it to a locksmith.
zlazar
13
Dec 24, 2007 07:11 PM
DsevenEm2
21
Dec 10, 2007 09:14 AM
mprznorth
May 1, 2006 06:36 AM
metal-x
Jan 20, 2003 01:02 PM
