So Cal 88-91 CRX Civic Si Transmission distributor and custom header
Old Jul 31, 2010 | 07:19 AM
rsanders21's Avatar
Default So Cal 88-91 CRX Civic Si Transmission distributor and custom header
I did a swap on a 89 crx si and these are all from that car. Everything works good as i drove the car before doing the swap to check everything out. The transmission is a 89 Si transmission with no grinds and the shaft is tight. Comes complete with mount reverse sensor, and negative battery ground. The distributor works good and teh bearing spins freely. The header is a custom header from a guy in barstow that does custom exhausts. It does have a little road rash but is in good shape. Its a 4 to 1 design. The transmission is 125 the distributor is 60 and the header is 50. I live in Hesperia in and i work in Perris so i can meet at either place or anywhere just off the freeway in between. Call or text me Robert 760 699 4579 Let me know if you want pics I can't ever get it to let me post pictures on here sorry.
innes887
Oct 23, 2007 07:09 AM
spoon*honda
Nov 24, 2004 06:39 PM
