Tranmission help!!
Old Jul 31, 2010 | 04:14 AM
gosu08's Avatar
Default Tranmission help!!
Something is wrong with my transmission. When I'm driving the car hard, my gears begin to stick and it's hard to put it into gear. And when I do get it into gear, it's hard to take it out. For example when I'm red lining 3rd to go to 4th, it feels as if I'm hitting a wall with the shifterbefore it let's me go into gear.
Any ideas?
I'm about to do a full transmission flush and clutch flush with new dot 3 fluid and GM syncromesh. I have never change these before an my car is at 65k now and making 500 hp.
Hope that helps. Any suggestions would be greatly appreciated.
Old Jul 31, 2010 | 04:46 AM
jdm_94's Avatar
Default Re: Tranmission help!!
did you check the fluid system?? I mean the clutch master cylinder or clutch pump both of them.
Old Jul 31, 2010 | 11:39 AM
gosu08's Avatar
i am about to bleed the master clutch cylinder and the transmission fluid tonight to see if that helps.
any other suggestions?
Old Jul 31, 2010 | 01:31 PM
SoTexDC2's Avatar
Inspect the shift linkage bushings as well.
If they're good and a fluid change doesn't fix the problem, it may be something internal.
Old Jul 31, 2010 | 06:11 PM
Steady R's Avatar
sounds like the clutch is sticking.
could be broken disc hub
Old Jul 31, 2010 | 06:56 PM
Quick99Si's Avatar
All those could be possible causes and more... from things that aren't common like a mount that throws the linkage out of alignment under engine load/rocking or bent shifter forks/interlock/shift rod, to more common things like gunked up fluid making it hard for the forks to push the synchro hubs into place. And that's not even getting into the clutch and related components.
I'd proceed with changing the MTF and doing a quick visual inspection of a few things like: slave cylinder (remove boot), clutch fluid level and operation, shift linkage bushings & retaining hardware, and the shifter itself. You can even move the shift linkage manually (in/out and rotation) while looking for loose parts, just keep in mind that the gears are sort of "backwards" when you're under there.
One last thing, make sure you use Synchromesh Friction Modified.
Old Jul 31, 2010 | 08:10 PM
jdm_94's Avatar
asked to my buddy about it and He told me that the same thing happened to him and the spring of the clutch disk were loose. Any strange noise??
Old Aug 1, 2010 | 01:54 AM
gosu08's Avatar
no there havent been any strange noises. i just changed all the fluids tonight (clutch and transmission).
i have problems especially with my 4th gear. sometimes it feels like im hitting a wall when putting into 4th and when it does go in, it doesnt want to come out...
i will drive the car around for a bit and see if the fluids flush helps though.
hope that extra info helps
Old Aug 1, 2010 | 08:44 AM
redGSRguy's Avatar
I too had a spring on the stock clutch disk pop out and it was hard to get in/out of gear...good thing I was able to make it to the shop.
Old Aug 1, 2010 | 02:08 PM
gosu08's Avatar
when you guys couldnt get it into gear, was it all the gears or just certain gears?
Old Aug 1, 2010 | 03:03 PM
fasthatch95's Avatar
We had the same problem yesterday in our b16 took it out right now and clutch was still new but the torque springs fell out of the disk, just thought i share this!
Old Aug 1, 2010 | 04:25 PM
thundernoodle's Avatar
hmm im having the same sort of issue too. my car doesnt g ointo 2nd under hard accel. it hits a stone wall and i have to let the revs drop. could be my clutch? I dont recall this problem with the oem piece.
Old Aug 1, 2010 | 07:01 PM
gosu08's Avatar
was this with only 1 gear or several gears? i thought if it was my clutch then it would be all gears...
Old Aug 2, 2010 | 12:44 PM
Steady R's Avatar
if you have weaker syncro's in certain gears those gears would be harder to get into. i felt 1-2 upshift would be harder, but was very knotchy in every gear
whats the mileage on your clutch and what brand is it?
i would pull the slave boot off and inspect the fork while you step on and off the clutch to see if your getting full travel. that would eliminate slave, master or any part of the hydraulic system
Old Aug 2, 2010 | 01:04 PM
racebum's Avatar
Originally Posted by gosu08
making 500 hp.
this is my guess on why you have a short transmission life. it might be time to talk with m factory for a build
Old Aug 2, 2010 | 01:54 PM
gosu08's Avatar
clutch is fairly new. competition stage 4 2000 miles max
i have only been on 500hp for 5 days now. this just recently started happening. my car has been down for 4 months building.
Old Aug 30, 2010 | 02:28 PM
gosu08's Avatar
i changed with gm synchromesh and it helped out. tranny shifts better but still grinds 2,3,4 occasionally when driving hard and the wall is still there on heavy driving.
I am probably going to need a new set of synchros for my ITR from what people have told me.
I saw that gear-speed sells a 1-5 synchro set for the ITR. Would I need new sleeves and synchro springs as well?
Old Aug 30, 2010 | 02:42 PM
youd have to look at them
hpimichael02
Oct 31, 2008 09:46 AM
s2kimportlover
Honda S2000
Mar 27, 2008 01:23 PM
civicandr6
Mar 16, 2007 07:18 PM
shiux
Mar 19, 2006 06:53 PM
VTechie
Jul 12, 2002 04:09 AM
