Gear knob fell off - where does the spring go?
Old Jul 30, 2010 | 06:40 PM
tom48's Avatar
Icon2 Gear **** fell off - where does the spring go?
While cleaning the gear ****, it magically fell off. (see picture)
I've been trying to put it back together, but can't figure out where the spring goes (what's its purpose anyway?). I know the white plastic piece has to be in a certain position so that the gear **** goes down all the way to the screw hole, but no matter what I tried, with the spring in place it won't reach to the screw hole.
Any ideas?
Thank You
Old Jul 30, 2010 | 06:51 PM
gianinline's Avatar
Default Re: Gear **** fell off - where does the spring go?
Spring goes at the tip of the chrome/blue piece, you need to keep it pressed and insert it inside the ****, and place the **** back on the shaft that you change gears. be sure to installe the white piece back, and remember to use the 2 small philips screws on the sides of the ****.
Old Jul 30, 2010 | 07:25 PM
tom48's Avatar
perfect. Thank you very much. Just put it back together and works like a charm. Thanks again
Old Jul 31, 2010 | 12:54 PM
JoeBull's Avatar
My chrome button would pop out sometimes when changing gears usally after backing up. I sanded the rough tips of two little phillips heead screws and never had the problem again. Keep this in mind if yours pops out.
Old Feb 16, 2011 | 04:06 PM
manojs1234's Avatar
Hi Tom, your post came up when I was doing a google search for the same issue. I have all the 4 pieces as shown in the above picture, but I can't still figure out how everything fits together. I placed the spring inside the know and then placed the chrome/blue piece on top of it. But what is holding the chrome/blue piece in place? Your input is greatly appreciated.
Thanks
Manoj
ramboPandA
Mar 27, 2018 02:00 PM
JC00925
Aug 19, 2014 04:54 PM
josh760
Jul 28, 2010 05:50 PM
.Hatches.
Suspension & Brakes
Aug 28, 2007 07:23 AM
gsr squirrel
Aug 29, 2001 04:06 PM
