HELP!! Has anyone ever seen an exhaust cam walk?? Pictures inside
Old Jul 30, 2010 | 04:48 PM
Spoolin18's Avatar
Default HELP!! Has anyone ever seen an exhaust cam walk?? Pictures inside
Well, I noticed this earlier today as I was going over the car. I was going to take it out for a spin, but when I looked down I noticed that the Exhaust cam gear was sitting out about a 1/4 inch farther than the Intake cam gear. So, I stopped and scratched my head like anyone would and wondered...what in the hell is going on here?? Everything is tight, all of the cam caps are perfectly tight, nothing is loose. The cam has actually walked itself over, and the lobe area has dug into the cam cap area. I have absolutely no idea how in the hell this has happened, if anyone has seen anything like this before please chime in and give me some insight. I hope I can salvage this head!
Just to give a run down of the head..here is what is currently in this head..
- Crower Turbo cams
- Crower .5 oversized valves
- Crower valve springs
- Crower retainers
- Ported
Here is the culprit...
Onto the damage...
Old Jul 30, 2010 | 05:27 PM
MrParks's Avatar
Default Re: HELP!! Has anyone ever seen an exhaust cam walk?? Pictures inside
pull the cams out and check the lengths on both cams shaft length and cam lobe mfg. and see if the ex cam matches the intake. seems like you have a defective cam.
there is no way this can happen with the cam locators on the dist side.
Old Jul 30, 2010 | 05:30 PM
Spoolin18's Avatar
I plan on pulling the head tomorrow evening and doing this. I hope that is what caused it, so it's an easy porblem to fix. However, the motor has been together for 5 years now and I thought if it was defective it would have done it way before now.
Old Jul 30, 2010 | 05:55 PM
slvrslepr's Avatar
I've seen this before. Crower cams breaking and taking out a 2500 dollar head. Will never use one of their products again. They are garbage. I'm sorry you had to find out this way.
Old Jul 30, 2010 | 06:16 PM
beavis's Avatar
Sorry Dustin, atleast you caught it before it got really bad.
Old Jul 30, 2010 | 06:33 PM
Spoolin18's Avatar
Yeah dude, it sucks but **** happens. I am glad I caught it too, I am hoping it can be salvaged.
Old Jul 30, 2010 | 07:01 PM
Cimburke23's Avatar
looks like the locator ring may have broken off or something? i would pull the cam cap on the distributor side and see if it is still there
Old Jul 30, 2010 | 07:17 PM
nonvtecallmotor's Avatar
Been there before... It probably broke the cam at the end. Its an easy fix.
Old Jul 30, 2010 | 08:28 PM
BADGUYNY's Avatar
the cam is broken... you can see it in the picture
Old Jul 30, 2010 | 08:49 PM
dester223's Avatar
Good eye. I finally saw it too after you mentioned it. At first I was just focused on where it was digging into the cam caps.
Old Jul 30, 2010 | 08:53 PM
1FASNIGA's Avatar
damn good eye i thought i was seein **** but damn thats an easy fix
Old Jul 30, 2010 | 09:06 PM
HIBOOSTKIRBY's Avatar
yup...same thing happend 2 my friend....it broke in 3 pieces like 6 years ago.....crower use 2 regrinding them back then...sucks but u just gotta get new cams..my friend had 2 get a new head..lol
Old Jul 31, 2010 | 04:17 AM
h22 civic's Avatar
comon prob with that crower junk........i will never use their product again either...long story short i bought a set of their cams when they first came out (bout 8 years ago) and broke a few sets ..started looking into them and alot of people broke them ,but when i approched crower on this they swore it was impossible...mean while its all over the internet ...lol fvckin b/s artist...
Old Jul 31, 2010 | 05:47 AM
sgnlab's Avatar
CROWER
Old Jul 31, 2010 | 01:59 PM
Spoolin18's Avatar
Do you guys think I can salvage this head with the cam cap areas looking that way?? I already have a new casting lined up, and was going to pull the head and transfer everything over.
Old Jul 31, 2010 | 02:03 PM
josh green's Avatar
I'm sure someone will tell you not to use it, but I cant think of a reason not too. Maybe have the cap and head measured and make sure it hasnt been reamed out. This is Crower stuff and not Brian Crower right?
Old Jul 31, 2010 | 02:04 PM
Spoolin18's Avatar
After going out, and looking at the cam again..you are correct. This is the culprit, the cam has snapped in 2.
Old Jul 31, 2010 | 02:05 PM
93-lsvtec-eh2's Avatar
it really depends how much material has been ground away and if your comfortable using the head after this. align hone on the cam journals should make sure it's still straight
Old Jul 31, 2010 | 03:35 PM
Spoolin18's Avatar
Posted the culprit...Crower cams are junk.
Old Jul 31, 2010 | 03:38 PM
Spoolin18's Avatar
Yes this is Crower, and not Brian Crower. These are the Crower Turbo cams, Stage 2 for forced induction.
Old Jul 31, 2010 | 05:42 PM
I would use the head again unless it tore up the journals. When I broke my cam isn the same place it marked the head in the same area and I'm still using the head 5 years later.
Old Jul 31, 2010 | 05:48 PM
Spoolin18's Avatar
I'm going to rock this head Rick, I checked over everything and it looks ok. The retainer overtop of where the cam broke in two has a few slight knicks in it, but nothing to worry about. All of the journal areas are still smooth and out of the two that have marks, neither of them have a lip of any kind. I think it will be fine, and there is only one way to find out!
Old Aug 1, 2010 | 07:58 AM
blessedshadow's Avatar
You are lucky enough mate, you worked things out with the Crower cams for 5 long years. Its better to replace them periodically as its subjected to aerodynamic and internal friction due to initial ripping of the car. Also keep the exhaust clean so that no pressure is applied on the cams..
Old Aug 1, 2010 | 09:38 PM
beavis's Avatar
Eff it, put another set in there and have a nice day
mouab18c1
15
May 6, 2011 11:22 PM
91redteg
10
Oct 16, 2007 09:38 AM
XiOus271
Jan 20, 2006 10:36 AM
