Simple hp gains?
Old Jul 30, 2010 | 04:42 PM
CTR_B's Avatar
Default Simple hp gains?
So my Gf wants to get in this local womens bracket racing thing. She's looking for some simple/cheap mods to gain a couple extra hp. Please don't come back talking about turbo/sc etc. We're only looking to lose a few tenths of a second donnish some simple mods or DIY mods would be great.
Thanks
Stock 2002 RSX-S with DIY air box mod
Old Jul 30, 2010 | 06:25 PM
PiNoY Ep3 SI's Avatar
Default Re: Simple hp gains?
For the money i would say go for a race header and a larger mid pipe. If you wanna spend a little more go for k-pro and have it tuned
Old Jul 30, 2010 | 06:42 PM
CTR_B's Avatar
At the moment all we want is a consistent 15.0 car.
The muffler already rattles so an exhaust is on a drawing table though the head not to sure about as FI is in the plans down the road.
Same goes for k-pro, it's in the works but funding won't cover it at the moment.
We're just looking for the best mods for the cheapest money at the moment. I ran the car last weds completely stock with A consistent time of 15.9/16.0 with 2.5 60fts. It cant be that hard to drop a .5 with these cars can it??
Old Aug 2, 2010 | 05:58 AM
turboteg2nv's Avatar
Learn how to launch properly before you do anything. I can hit 2.1 60fts w/ street tires lowered to 20psi.
You won't be able to make power if the ECU is still trying to override/correct everything. So until you get Kpro I wouldn't even mess w/the engine.
Try to strip unnecessary weight first (interior panels/seats, spare tire, GF, etc.). For cheap mods, you could fill the motor mounts with poly window filler stuff, that might help with your ridiculous 60ft times.
Old Aug 2, 2010 | 06:04 AM
Evasion's Avatar
The easiest and CHEAPEST thing you can do to drop time is get rid of some weight. Every pound you can get rid of helps in track time. You may not be adding HP, but you'll be using the HP you have will carry you faster with a lighter car. I havn't done this with my RSX, but did this with my supra back in the day and it helped in my track times.
-If you have the spare tire in your car, take it out on race day. That's 20 pounds gone by itself.
-Take out the back seat, including setbelts.
-Take out the carpet in the back and the hatch area + any molding.
Those are just some of the easiest ways to get rid of 20-40 pounds of excess wieght. All of these can be easily replaced as well, if you took them out correctly. A friend of mine auto crosses and goes as far as drilling holes in his bumpers to reduce wieght. lol
Old Aug 2, 2010 | 07:12 AM
DaveSi677's Avatar
drilling holes in your bumper isn't for loosing weight but to have less drag in the rear...
Honestly just remember one thing its all about power to weight ratio... it's the only thing that matters when it comes to racing! Loose some weight, upgrade clutch and flywheel, get better tires will all help you get better times going down the strip!
Old Aug 2, 2010 | 07:30 AM
Charisma's Avatar
It's bracket racing. Could be a 15 second car or a 20 second car... Doesn't matter.
Anyway, you want to pick up some simple power... Race header + exhaust.
What'd I'd highly recommend is the following.
RBC + Karcepts adapter
KiddRacing Race Header
3" cat-back
Cold Air intake
Kpro + dyno tune
She will have a blast like that. But if she wants to actually go fast and be consistent, get some BFG drag radials on the stockies or on a set of 15" with proper backspacing/offsets to clear the brakes.
Old Aug 2, 2010 | 08:13 AM
nahonda04's Avatar
Surje.motorsports
3" cat-back
Cold Air intake
Kpro + dyno tune
perfect post...beat me to it!!
Old Aug 2, 2010 | 10:59 AM
CTR_B's Avatar
Thanks guys! Appreciated
Old Aug 3, 2010 | 05:51 AM
Charisma's Avatar
No problem, let me know if you need any help/insight.
Old Aug 3, 2010 | 08:19 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
intake & weight reduction
Old Aug 23, 2010 | 06:11 PM
ponverb's Avatar
Wheel/tire overall size due to the 0-mph/kph - danger requires more to turn the larger radius. Coilovers/Camber should ensure you are in contact once you are rpm'ing.
Old Aug 23, 2010 | 06:41 PM
thatgreeneg's Avatar
my opinion is nice clutch and a ligh flywheel and get rid of seats and anything that makes the car heave
Old Aug 23, 2010 | 08:52 PM
hawaiiancb74's Avatar
whats the point of adding hp to a bracket car? but none the less intake header exhaust.. and kpro.. enjoy.
Old Aug 23, 2010 | 08:53 PM
oh and lots of time at the test and tunes getting the pattern down
Old Aug 27, 2010 | 07:57 PM
WhiteOnRice's Avatar
Tires
Old Sep 5, 2010 | 05:47 PM
ponverb's Avatar
I thought HONDATA Reflash was best for a standard bolt-on mod ? Please link me to a post or thread somewhere or explain
Old Sep 6, 2010 | 09:01 AM
not to be a dick but i think you will find what i say goes.. i rarely have to link something to prove it because ide just be linking you to something i said earlier.. like one of the 900 times Ive said reflash is a waste of money. kpro is always better.. ALWAYS and in this case they can use to kpro to set the rpms for the car and everything she would need so she can run a more consistent time. welcome to the forum btw!
Old Sep 6, 2010 | 01:39 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
In simple form:
NO TWO CARS RUN THE EXACT SAME... even though we have the same motor, my dyno graph will be different than yours. So if you want the most power, the best safety for your engine, and the best tune, you need to get Hondata K-pro and have your engine tuned to YOUR ENGINES SPECS!
Installing a reflash is a waste of time and a joke to me. I see it as being like buying a power chip back in the day add. You are putting someone elses tune in your car. How do you know it's not hurting more than helping? People talk about reflash leaning out your setup.
K-pro to me is one of THE best mods if not THE best.
Old Sep 8, 2010 | 10:00 PM
cscdc5's Avatar
Kpro and weight loss
Old Sep 12, 2010 | 01:30 PM
JSeoul's Avatar
Seat time. Mods won't do **** if she can't launch correctly or misses a shift. Spend the $35-60 in attending the track.
Old Sep 14, 2010 | 09:28 AM
blueshark123's Avatar
awd conversion
Old Sep 14, 2010 | 10:29 AM
DaveSi677's Avatar
Originally Posted by blueshark123
awd conversion
Hahaha
Old Sep 14, 2010 | 01:42 PM
DC5DC2's Avatar
on race day just take off the rear seats, the spare tire along with the tie down bose speaker and the passenger side seat. this wont cost u anything, throw in an intake and have her practice launching and shes set, intakes run u bout $100 in the streets and or on ebay, if u still have some more $$ then invest on some race headers and exhaust and u should break hi 14's. I have an 06 RSX type S with an AEM V2 intake and i took out the interior above an i ran 15.1 and im a heavy set guy so she should be fine.
Old Sep 14, 2010 | 07:24 PM
AdamNJK20's Avatar
Originally Posted by Type-'S'paz
In simple form:
just pay attention to this
