FS All Infinity Kappa system, components, 12" sub, amp! New line products. Will ship
Good afternoon everyone, I am wanting more money to get more HP in the fit. All I'm gonna say
All this equipment is in PERFECT condition. I baby everything. Nothing is blow, rigged, ghetto. I have receipts for everything. Most of this equipment comes with a 6 year warranty. Ive owned it for less than half a year. Will ship at buyers expense.
Only trade items I'm interested in is adjustable coilover suspension. Preferable Skunk2 Pro C.
Lets work out some deals ^_^ Prices are workable just not retarded plz :hyper:
All prices are before shipping.
Infinity Kappa 10.9T New - $129.99 SOLD
The box I have it mounted in is perfectly measured and designed to make this sub operate to its fullest.
Box is: Sub Box: 1SL12-1.0 (Black) its 1 cubic foot exactly.
Infinity KAPPA FIVE AMP New - $499.99 SOLD
I researched an *** ton to build this system over time. Everything is high quality equipment. Read the product reviews about this equipment online. You will understand why I chose it. I'm super OCD about almost everything and my attention to detail attribute is off the chart. Trust me, you will not be dissatisfied at all!
- 2-way 6-1/2" speakers (pair)
- fit 6-3/4" openings
- True Four Ohm Impedance technology: speaker's 2-ohm impedance combines with speaker wire impedance for a 4-ohm load
- compatible with virtually all factory or aftermarket car stereos
- Plus One® woven-glass-fiber woofer cone with hi-roll rubber surround
- 1" rotating UniPivot, edge-driven M.M.D.® dome tweeter
- computer-optimized outboard crossover with tweeter level control
- direct-connect crossover dongle
- power range: 2-75 watts RMS (225 watts peak power)
- frequency response: 45-25,000 Hz
- sensitivity: 95 dB
- top-mount depth: 2-5/16"
- warranty: 3 years
- 6-1/2" component speaker system includes woofers, tweeters, and crossovers
- 1" ultra-high frequency textile dome tweeter with I-Mount™ and Starfish™ for multiple mounting options
- 2-way external crossover network with tweeter level adjustment
- power range: 2-90 watts RMS (270 watts peak power)
- frequency response: 45-35,000 Hz
- sensitivity: 93 dB
- woofer top-mount depth: 2-7/16"
- warranty: 3 years
- 12" subwoofer with selectable 2- or 4-ohm impedance
- coated glass-fiber cone with rubber surround
- cast aluminum basket
- frequency response: 23-400 Hz
- power range: 50-350 watts RMS (1,400 watts peak power)
- sensitivity: 91 dB
- top-mount depth: 6-3/8"
- sealed box volume: 1.0 cu. ft.
- ported box volume: 2.0 cu. ft.
- warranty: 3 years
- 5-channel amplifier
- 50 watts RMS x 4 at 4 ohms + 200 watts RMS x 1 at 4 ohms
- 75 watts RMS x 4 + 300 watts RMS x 1 at 2 ohms
- 150 watts RMS x 2 + 200 watts RMS x 1 bridged at 4 ohms
- CEA-2006 compliant
- variable high- and low-pass filters (32-320 Hz, 12dB per octave)
- bass boost: 0-12 dB
- frequency response: 10-75000 Hz (front and rear); 15-320 Hz (subwoofer)
- Non-stop Thermal Protection ciruitry
- Class-D amplifier design
- differential balanced speaker-and preamp-level inputs
- 4-gauge power and ground leads and a 80-amp fuse recommended — wiring and hardware not included with amplifier
- fuse rating: 40A x 2
- 7-1/16"W x 1-3/4"H x 14-3/16"D
- warranty: 1 year
WAT THA!!!
Jul 2, 2006 10:56 AM
WAT THA!!!
Jun 18, 2006 10:35 AM
