TX FS: Final Speed Eraser 16 X 7 et 38 + 2 sets of tires! $400 JDM Discount YO! Must see
Good afternoon all,
Due to my Track Junkie addiction, I have purchased a new set of wheels and tires to disguise myself as a miata. So old set up is for sale. here goes the description.
WILL SHIP! this price is BEFORE SHIPPING
JCrim
Tyler, TX
Price: $400
Wheels: Final Speed Eraser 16 X 7.0 et38, 4 X 100
http://www.marukanet...ech/eraser.html
Tires (set 1, these are currently mounted): Toyo T1R 205/45/16 60%+ TREAD LIFE REMAINING!!! (besides 1 that has inside wear do to my alignment at the time
I just bought these things in March.
TOYO T1R
- New "Generation S" silica-reinforced, high-grip tread compound
- New silica compound that minimizes heat build-up
- Rigid shoulder rib-bands that improve cornering
- New "Generation S" silica-reinforced tread compound with higher wet-u
- Refined V-shaped main grooves for improved resistance to aquaplaning
- T-Mode Design Technology
- Rigid shoulder rib-bands that improve response
- High-modulus bead apex rubber
- High-modulus casing (rayon or polyester depending on size)
- Wide high-tensile steel belts
- Spiral-wound, jointless edge and cap plies (construction may vary by size)
- Jointless bead wire
- High-tensile belt reinforcement cap layer (construction may vary by size)
- Rigid shoulder rib-bands that reduce irregular wear
- Rim protector
- High-dispersed silica that improves wear resistance
- Ultra-high molecular polymer that increases wear resistance
- Refined unidirectional tread pattern
- Optimized, low-profile design
- Modern sidewall styling
- V,W, and Y speed-rated (depending on size)
- UTQG Treadwear 280
- UTQG Traction AA
- UTQG Temperature A
Tires (set 2 all seasons): Yokohama AVID H4 205/45/16 40% tread life on 3, 10% on 1 of them. once again tread wear due to gheto old alignment
PM's welcome. or however you know how to contact me.
JCrim
Tyler, TX
Price: $400
TOYO T1R
- Rim protector
- UTQG Traction AA
justagsr
Texas -OK -LA (Sales)
27
Jul 16, 2006 11:48 AM
