brake upgrade
Old Sep 16, 2002 | 12:09 PM
wadafa's Avatar
Default brake upgrade
yeah i know this has prolly been posted up bout a million times, sorry, just some specific q's on it
i got an HF, will my axles fit the ex knuckle/hub assembly or will i have to keep my hubs and put them on the new knuckles?
is the 90-91 ex MC a 15/16" bore, and will my lines bolt up or do i need ot modify them?
thanks
Old Sep 16, 2002 | 01:39 PM
andrew dc's Avatar
Default Re: brake upgrade (wadafa)
need new knuckles
and yes to your mc question
Old Sep 16, 2002 | 07:52 PM
wadafa's Avatar
thanks for the MC confirmation,been gettin mixed answers bout this,
about the knuckle though, basically are the outer splines on an HF the same as the ones on an SI?
CRX 25: did you mean need new knuckles but keep the HF hubs??
thanks,
man first post and already a good answer, unlike some other places i've been too
[Modified by wadafa, 4:53 AM 9/17/2002]
Old Sep 16, 2002 | 09:18 PM
andrew dc's Avatar
when I swapped my hf.. I just want to the yard to get the whole knuckle... I think I, as well as many am confused with the term hub... in anycase, the knuckle swap is pretty straight forward.... im me if you need help
Andrew
Old Sep 18, 2002 | 04:39 PM
wadafa's Avatar
Default Re: brake upgrade (CRX25)
the hubs are pressed on to the knuckle right?
the axle goes into the hub, so if the axles from the HF are different from the ex, (the outer splines are different, i think???), they would not fit properly
Old Sep 18, 2002 | 06:24 PM
79 civic's Avatar
the splines are different yes, you could press in some si hubs and use the axles from the si. or, you could use the original axles and put 4x120 hubs on it from a 79 civic 1200. but that would defeat the purpose.
if you do get the uprights from the ex or anything you would still need to get axles to fit.
PS122
Sep 20, 2009 08:17 AM
KhmerdudeSiR
Nov 12, 2008 07:48 PM
cb07
Apr 7, 2008 07:15 AM
ceyazzie
24
Nov 25, 2007 05:54 AM
muskrat
Dec 30, 2002 05:43 PM
