Spoolin' Performance Turbo Setup, and more goodies!!
GM Boost Control Solenoid
Same function as the MAC solenoid
$15 Shipped
Fastline Oil Pan Baffle Set
Never installed. They have a little bit of surface rust, but 30 seconds with a scotch-brite pad before you weld them in will clean it up.
$20 Shipped
Boost Leak Tester
Custom made. Just hook it up to a compressor or air tank and listen for leaks. Includes cap for throttle body end of tubing. Made for a 3" compressor inlet, and a 2.5" charge pipe near the throttle body.
$25 Shipped
Earl's -4 Oil Feed Line
33 inches from fitting to fitting. Good for a larger feed line.
$15 Shipped
B16A3 Valve Cover
Painted red over the factory black wrinkle finish. Not pretty on the outside, but super clean on the inside.
$55 Shipped
D16 "HONDA" Valve Cover
Pretty clean, never painted or modified.
$40 Shipped
B16A3 Intake manifold and throttle body
Good condition. This is the manifold you need to pass the California BAR inspection with a B16 because it has the fitting for an EVAP purge valve. Sensors included are: MAP, TPS, IAT, FITV, IACV and lower brace bracket. No EVAP purge valve.
$85 Shipped
All prices are OBO. Contact Jon at (206)849-1123 with offers! Thanks for looking!
$15 Shipped
$20 Shipped
Boost Leak Tester
$25 Shipped
$15 Shipped
B16A3 Valve Cover
$55 Shipped
$40 Shipped
$85 Shipped
ub3rn00ber
Jan 22, 2011 09:29 AM
ub3rn00ber
Jan 20, 2011 09:21 AM
WrongWD
Aug 24, 2010 07:56 AM
stealthmode62
Nov 17, 2005 01:59 AM
