car starts then dies
Old Jul 30, 2010 | 08:48 AM
fijisac's Avatar
Default car starts then dies
OK i have a 91 civic DX, DPFI, D15b2, and its 100% stock with automatic transmission. When i start the car, i have to push the gas pedal all the down so it starts and it runs for like a two minutes then dies. i have to give it some gas in order to keep it running but then still dies even if i give it gas. If i start it and let off the gas then it dies. There are no codes. Can someone please help me out cause this is the only car i have to get to work.
here is a list of thing i have done to it.
main relay
fuel pump
fuel filter
dizzy (distributor)
cap and rotor
plug wires
spark plugs
valve cover gasket
oxygen sensor
fuel pressure is at 39 PSI
compression is 170 PSI across all 4 cylinders
only 149,000 miles on the car
SpeedoKing
Nov 15, 2008 07:22 PM
ehonda1980
May 21, 2008 04:55 PM
jjmajed
May 15, 2007 07:12 PM
flyguy0086
Jan 23, 2007 10:11 PM
DA6_toojy
Oct 12, 2005 06:30 PM
