89 to 91 guage cluster wiring changes?
Old Sep 16, 2002 | 11:57 AM
spettinger's Avatar
Default 89 to 91 guage cluster wiring changes?
going from an 89 CRX SI cluster to a 91 hatch SI cluster, what are the wiring changes in the harness? thanks!!
Old Sep 16, 2002 | 12:04 PM
SuperCivic's Avatar
Default Re: 89 to 91 guage cluster wiring changes? (wreckedhatch)
here's what i did..
http://b16a.honda-perf.org/cluster.html
look at the chart for 90 crx si..that is the pin out you want. you can also refer to the printed circuit board on the back of the cluster to trace pins to sensors..it's not too hard. when you repin you will have to lengthen a few wires as well.
Old Sep 16, 2002 | 02:21 PM
spettinger's Avatar
Default Re: 89 to 91 guage cluster wiring changes? (SuperCivic)
the only noticeable difference between my guage cluster plugs is the middle connector on the 91. it is a 5 wires plug, only 3 wires in it on the 89, the 91 plug has all 5. any ideas? thanks.
Old Sep 16, 2002 | 05:10 PM
spettinger's Avatar
bump
Old Sep 16, 2002 | 07:14 PM
spettinger's Avatar
rewired the 2 main plugs, any ideas on the middle? on the 89, it has 3 pins, on the 91 there are all 5! thanks!
Old Sep 17, 2002 | 04:40 PM
spettinger's Avatar
bump--- if i remove the VSS amp on the back of the cluster, will it throw a check engine light?? thanks.
widewhite
Sep 10, 2016 11:32 AM
esemze
Aug 17, 2005 05:29 PM
spettinger
Jun 14, 2002 08:02 AM
