Will RSX-S Brembo rotors fiton integra?
mike_teg,
the RSX-S front rotor re-drilled to 4X100
will not work on your integra;
unless you have done
the front S2000 (or RSX-S) caliper
brake upgrade on a civic EX/integra knuckle.
the s2000 caliper's brackets will need to be
machined (or milled) in order to clear.
once the machine work is done,
everything is a bolt-on
99.9% sure that it will clear
your 17" wheel w/ +45 offset
contact honda-tech member: BE2 for more details
Yes, once redrilled they fit. They use the same offset/spacing/center bore as the Integra.
If you are planning on using the Integra caliper it needs to spaced outward an inch. Otherwise you need the TypeS/CR-V 11.8 caliper.
