ecu code 7 blinks TPS?
hey guys im running a 90 teg ecu on my first gen b16 and the idle goes up and down from 1,500 to 2,000 it just goes up and down, my ecu blinks 7 times is this the tps sensor thats making my car idle weird??
ur TPS sensor its messed up
the sensor its not sendind the right resistance to the ecu wich makes the idle not be accurate wich means bad fuel timing, wich means bad idle... change the sensor and then tell us if it still does it...
92eg6_pino
Aug 16, 2005 07:53 PM
VTgringo
May 19, 2003 08:03 PM
