JDM front fog's stopped working
Old Jul 28, 2010 | 09:46 PM
d8168055's Avatar
Default JDM front fog's stopped working
Both fog lights flickered and went out one day, and they dont turn on anymore. They have worked for the 10 or so years that I have had the JDM conversion done, so it is not a wiring issue.
I used the harness from an old set of PIAA fogs, and they worked fine until now. I can hear them clicking when I flick the switch, but will not turn on. I haven't been able to check for any blown fuses yet, but I am thinking it is the relay switch that may busted.
What do you guys think? should I order a new relay (PIAA #PL5FA)? is there a test i can do to see if it is really busted? like.. volt meter or hard wire?
Old Jul 28, 2010 | 10:02 PM
d8168055's Avatar
Default Re: JDM front fog's stopped working
hahah i just read what i typed... i guess the most obvious answer is that the bulbs blew out... but i found it suspicious that both would go at the same time? or.. if one goes, it interrupts the circuit.. and both go?
Old Jul 29, 2010 | 07:30 AM
94rs-turbo's Avatar
sounds like a relay to me but ya, check the bulbs to see if they're blown
Old Jul 29, 2010 | 08:15 AM
Dr. DC2's Avatar
Old May 10, 2011 | 02:28 PM
Jmcm1227's Avatar
im having the same problem, the relay clicks and everything works but the thing is i have to keep turning the switch on and off until it turns on.. lol..
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
BrayzieEF9
20
Feb 8, 2010 06:08 PM
lilo_goki
Lighting
Oct 29, 2007 12:10 PM
B204door
Audio / Security / Video
Dec 21, 2006 04:03 PM
Joon Joon
27
Oct 23, 2005 05:49 PM
