b16a3 in eg
Old Jul 28, 2010 | 08:00 PM
andocommando's Avatar
Default b16a3 in eg
so i have an ex civic eg with abs and i need to know what all i need to get that sucker in there and running
i know about the integra linkage and that the only mounts i can use are the ones out of the b16 del sol
but im not sure about the harness and ecu
Old Jul 28, 2010 | 08:32 PM
-__-'s Avatar
Default Re: b16a3 in eg
Re-use EVERYTHING out of the delsol except the shift linkage. i believe the delsol B-series linkage is different. ANY integra shift linkage will work fine. Other than that, use the mounts, ECU and harness from the delsol.
Old Jul 28, 2010 | 08:55 PM
will that harness work with the abs?
Old Jul 28, 2010 | 09:22 PM
-__-'s Avatar
hmm not sure about that. i believe the ABS wiring is part of the chassis? someone clarify? and if not, u can just use your stock civic harness. they are the same. your car is an EX so i assume it still have the SOHC VTEC engine? If so, the harness will work just as well as the delsol one.
Old Jul 29, 2010 | 05:41 AM
fv8s's Avatar
you do not need a new harness. you may need to extend a few wires
Old Jul 29, 2010 | 07:52 AM
HAMOTORSPORTS's Avatar
The abs plugs are part of the chassis/cabin harness that runs along side the framerails. It is not involved with the engine harness. If you were able to pick up the Del sol harness with the engine, use it. Otherwise, use your EX harness and you'll just have to extend a few plugs.
Old Jul 29, 2010 | 09:48 AM
Str8EJ's Avatar
+ do something about the B16's knock sensor, which the D16z didn't have.
If you are using an aftermarket programmable ECU, disable that sensor.
If you are using a factory program ECU, add the wiring.
Axles, radiator hoses.
D3U1LT
May 14, 2015 06:31 AM
dE.fUsEd
Apr 17, 2012 10:42 AM
D3U1LT
Aug 23, 2006 04:06 PM
Natural Aspirations
Jun 30, 2005 08:21 AM
adictionbass
Jan 12, 2005 04:14 PM
