Qs on putting 01 ITR LSD into 94 GSR tranny.
I did a search and from what I understand it will bolt right in. Is that right? Also somebody mentioned something about bearings being different. Do I use the tapered ones or the square ones and which tranny are they from?
Also when I go to get the LSD what should I look for? How can I tell if it is an ITR LSD and can I tell if it is damaged?
TIA.
TIA.
these ? are frequently asked and answered here ... the answer is yes they fit, use the carrier bearings that are in your tranny, i.e. if square use square if tapered use tapered. You can tell any LSD tranny by looking thru the axle hole, it should not have a pin going across it.
Greg
Greg
hmm are you positive cheetah? I think the newer ITR's and newer GSR's use a different axle spline and you might need new axles to match as well. Reason i say this is because i was looking at the acura carland parts pages and for early GSR's they use the same axle part number as the LS's, but the newer GSR's and ITR's (I only looked at 2001) used a different part number.
Reason I say this is because i just bought a gsr transmission for my LS and am also trying to figure this all out before i get a lsd that doesnt' work
[Modified by 8Ball, 8:37 AM 9/20/2002]
hey what is the difference between a HELICAL LSD and a regrlar lsd
sorry for the stupid question
s
thanks alot for clearing up that
another question
i want to go with the itr lsd but my friends said that they are crap i should just save my money and go with the quaiffe one (they cost soooo much)
what do you think
any help would be great full
another question
what do you think
positive ... I've interchanged many 2001 trannys with the older axles. B-series ends are the same, just the lengths of the axles change and cannot be used interchagebly, etc.
greg
greg
DevinW
Jun 17, 2003 02:56 AM
