Piston valve clearance
Old Jul 28, 2010 | 03:44 PM
P'cola GSR's Avatar
Default Piston valve clearance
Ive searched and i cant find any usefull info on this topic, im currently running type r pistons on itr valves and gsr cams, now if i put the gsr pistons back in would there be an clearance issues?
Old Jul 28, 2010 | 04:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Piston valve clearance
If you think about your question for a minute, you would be running gsr pistons with gsr cams (valves make no difference unless you were running oversize).....so your car would be operating at stock specs....
If they worked with type R pistons which have a much higher dome/compression height, then why would they have clearance issues on something that gives you even more clearance?
all-mtr-teg
Aug 12, 2007 06:33 AM
b20powereDA
Jun 21, 2007 04:40 PM
beaterdriver
13
Aug 31, 2004 11:30 AM
colt45.5
Apr 27, 2004 06:47 PM
Aaron.Hillman
Mar 15, 2004 04:11 AM
