d15b2 head bolt hole... block fubar?
Old Jul 28, 2010 | 12:28 PM
DeeEx Rex's Avatar
Default d15b2 head bolt hole... block fubar?
So here is my dilemma. There was significant oil leak coming from the head gasket so I prepared to change it. I was ready to un bolt the head so I started in the correct order, bolts 10 through 6 were coming loose fine, bolt 5 was incredibly tight coming out. After getting the bolt out I found that the last half inch of thread was completely gone, which leads me to believe whoever had the head off last either cross threaded the bolt somehow or had re used old head bolts.. I tried running the new bolt in to the hole but it wasn't threading, it just kept spinning.. so I tapped the hole and still the same result.
So my question is, aside from the obvious need for a new block, is there anything that can be done to avoid having to swap out the block? Could a machine shop possibly fill the hole and re drill/tap it? Is there a larger thread bolt that I could use? This is my DD right now so all help is greatly appreciated..
Old Jul 28, 2010 | 12:48 PM
DeeEx Rex's Avatar
Default Re: d15b2 head bolt hole... block fubar?
http://www.automedia.com/Thread_Repa...es20021201tr/1
Anyone think this would be worth a shot?
Old Jul 28, 2010 | 01:59 PM
75euRFE's Avatar
take it to a machine shop and have them helicoil it.
Old Jul 28, 2010 | 02:32 PM
DeeEx Rex's Avatar
That's what the kit is that I posted above, anyone have experience with using that on a block? Will I run into compression/oil leakage problems?
Old Jul 28, 2010 | 09:37 PM
D16SiHatch's Avatar
if it's done properly it will work just fine.
it's only a b2 block we're talking about here so you could always just find another one for cheap.
Old Jul 29, 2010 | 05:33 AM
DeeEx Rex's Avatar
Yeah I hear ya, I'm going to use the heli coil kit this weekend, I'd hate to waste a perfectly good bottom end. Thanks for all of the responses.
Old Jul 29, 2010 | 06:08 AM
8VEYBEYB's Avatar
one time I ripped the metal threads n all out of my block for the timing belt tensioner , I used a welder and helicoil and it was good as new.
Old Jul 29, 2010 | 08:57 AM
DeeEx Rex's Avatar
Good deal, hold up okay?
Old Jul 29, 2010 | 10:16 AM
TJChad's Avatar
you're not "supposed" to use a helicoil for head bolt threads but honestly I think you would be fine using them. We used to use them in TONS of spots with a good amount of stress for repairs on our blackhawks (heliciopters) Just make sure you get a GOOD kit there are plenty of cheap *** kits out there.
Old Jul 29, 2010 | 10:42 AM
DeeEx Rex's Avatar
I just called autozone to see if they carried them and they do, not sure of the brand though but I'll post it when I get home to see if it's something you would recommend.. their stuff isn't always the greatest lol
Old Jul 29, 2010 | 11:02 AM
TJChad's Avatar
Ive seen the kits from autozone, they're not TOO bad, they could be worse. Just make sure the kit will come with the right thread size/pitch that you need for your headbolt, also the drill bit and helicoil insert tool
sh!ft
Dec 20, 2009 05:02 PM
Hondaholik
Jul 24, 2006 04:47 PM
Hondaholik
Jul 24, 2006 02:31 PM
zbower7
Mar 4, 2004 09:35 AM
