Fresh built ls/vtec 1.9l (pro2's, ported head, valve job, degreed already)
Located long island, ny 11772 $3500 obo
Shortblock
97' b18b block cleaned, decked, align honed, and cylinders bored/honed
00' ls crank balanced, micropolished and graphite coated
pr4(ls)rods balanced, shotpeened, big ends resized for arp bolts
rsmachine 81.75 pr3 pistons with hastings rings balanced
Z-10 girdle with arp gsr mainstuds
acl bearings
goldeneagle ls/vtec set with 82mm headgasket
gsr arp headstuds
8mm arp rod bolts
Mfactory magnetic drain plug
Cylinder head
00' b16 head (Hot street port and polish, 3 angle valve job)
super-tech valvesprings & retainers
super-tech high compression valves
skunk2 pro2 cams
skunk2 cam gears
Here's what you will get (header not included in sale but available to buy extra 450 shipped)
Fresh bore and hone
Z10 main girdle with arp main studs
Golden Eagle ls/vtec oil line kit
ACL bearings
Crank with the journals graphite coated
pr3 piston on ls rod
The assembling has begin!!!
CCCylinderheads.com Headwork
Valve 2 Valve and R2VS measuring
Head installed for piston 2 valve measuring and degreeing
Still need to get the manifold bead blasted to clean it up.
Intake manifold bead blasted and new pro fab header
Shortblock
acl bearings
gsr arp headstuds
8mm arp rod bolts
Cylinder head
skunk2 pro2 cams
skunk2 cam gears
Fresh bore and hone
ACL bearings
96Spec Ek
Apr 9, 2011 04:43 AM
96Spec Ek
Jul 25, 2010 03:30 PM
96Spec Ek
62
Sep 9, 2009 08:25 PM
