OBD1 Dizzy Issues on 88' Crx...
Old Jul 27, 2010 | 08:11 PM
Mugencrxsir1's Avatar
Default OBD1 Dizzy Issues on 88' Crx...
Hey guys, my last part of my Ls/Vtec project to figure out is to find out which OBD1 Distributor fits like the stock gen 1 b16's TD-22U.
I order the standard TD-44U dizzy that everyone recommends for the OBD0 - OBD1 conversation but it fit horribly so I returned it...
I did some research and here's probably why... The TD-44U is meant for the GSR head and as most parts go the GSR and B16 heads are very different and most parts don't mix/match...
So my question is what is everyone using on their Gen 1 B16 heads for OBD1 Conversations?
From what I can see, the TD-42U from the 92-95 Civics and Del Sol's should work and possibly the TD-87U which was meant for the Type R's which basically had B16b heads and those parts are interchangable!!!
Thanks for your help guys, I do apprecate it and yes I've SEARCHED...
Anthony
Old Jul 27, 2010 | 09:34 PM
mattliston's Avatar
Default Re: OBD1 Dizzy Issues on 88' Crx...
have you tried an obd1 b16 ecu from a 94-95 del sol vtec trim model?
should fit
Old Jul 28, 2010 | 12:46 AM
Deetz's Avatar
Crazy Honda Guy
I use a TD-44U for my 1st gen B16A swap...it's a real oem dizzy, not aftermarket like 99% of the ones out there, fits and works perfect!!!
Are you sure you put the dizzy in the right way, not 180 degrees out???
Old Jul 28, 2010 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
b series head castings are essentially identical, any DOHC VTEC b series will fit physically
Old Jul 28, 2010 | 03:29 AM
crx_si-r's Avatar
Did you get it from an auto parts store? What part number did you get? If you get an a1cardone part get this part # 31-17407, this is for the td44 dizzy. When bought mine from my job I had to read it carefully. I looked it up for a 95 del sol vtec model and it listed both the sohc and dohc for the b16. Could be you got the sohc by mistake.
Old Jul 28, 2010 | 05:06 AM
Nah my biggest mistake is I purchased my original TD-44U off Ebay, and I was wondering if the cheap casting was the problem... But that Dizzy looked perfect, but just didn't fit as the center shaft was off a few mm and the bolt holes were off as well... Meaning the dizzy would sit at an angle!
As for the the other question, no I'm pretty sure I was not 180 degrees out or up side down as the bolt holes only line up one way...
I'll look up a few different part numbers and see what you guys think! The last thing I ever thought is that a TD-44U wouldn't fit...
Thanks,
Old Jul 28, 2010 | 12:09 PM
Okay after looking at this link:
http://www.streetimports.com/products.asp?catid=94
I think I'm leaning towards the TD-68U which is suppose to be exactly like the TD-44U... But hopefully this company doesn't use Tawainese castings!
Any other advice or help would be awesome!
Thanks,
Anthony
postman
Oct 27, 2005 12:26 PM
SuperRacerTypeR
13
Oct 5, 2005 07:48 AM
RACEPAK
Sep 11, 2005 12:43 PM
hatchii
Nov 15, 2002 08:15 PM
