245/35/17 - 215/40/17 Low offset guys help!
Hey guys, i've got some work Vsxx and there 17x9 ET36 rear and 17 x 8 ET30 fronts.
Firstly, is this double with the tyre size in title without any flaring ?
I know i'll need to run around -3 camber all round and i want to run quite low.
Any input would be more than apprciated as i want to buy my tyres asap.
Cheers Rob
Cheers Rob
Anyway, you do realize with the size you mentioned that the rims will be sticking out a couple of inches right? You want that look?
Also, you will need to flare the fenders even if you don't lower it. Not just roll them, but flare them. Also, just to make sure you also know it will ruin the handling quite a bit, right?
^^^ Definitely won't stick out a few inches
But yeah that tire size should be good, I have a similar set up, my fronts are 8.5 though and all I have is a slight roll and wheels fit fine, and it won't drastically hurt handling unless you plan on tracking your car.
