garage clean out and shell
Everything will be best offer and buyer pays shipping unless pickup. Will have pics soon.
need to sell because im leaving for boot camp in Jan
From 2003 Civic SI: PRB intake manifold/plastic engine cover/38920-PNF-004 belt/tensioner
95 Integra SE coupe shell
JDM EG Stanley clear corners two sets: one for sedan one for hatch
Sylvania Silverstar H4 bulbs
Nokya Super White H4 bulbs
clear H3 bulbs
Stanley H4H bulbs (for JDM headlights)
4 OBD-1 injectors
OEM dual bend shifter
STR cam seal red
USDM EG clock
EG clock blocker
Vigor alternator belt 38920-P30-004
DA intermediate shaft seal 91260-SK7-013
IAT sensor
oil pressure sending unit
NEC ignitor
OBD-0 fan switch
DC fuel cap holder
rear cargo light EG or DC
antenna hole cover
1/8" NPT pipe tap with plug
2 90* brass fittings for fuel pressure gauge
2 caliper rebuild kits
various bleeder valves 8mm x 1.25
MicroGard PCV valve FV299
EG rear glass bolt with rubber spacer
Omni power rear bolt and washer camber kit
2 driver side 1 pass side EG headlights USDM
OBD-0 B-series throttle body
Eg front lower control arms L and R
L and R front upper control arms
2 EG DX pass side spindles
DX driver side caliper w/ bracket
rear driver side drum trailing arm
2 muffler silencers
OEM FPR
OEM fuel rail
B-series auto tranny/torque converter/inter. shaft/pass side and rear mount
auto throttle cable and new starter
2 EG DX auto clusters
2 stock B-series headers
EG e-brake cover black
driver and pass EG seats grey
DC front sway bar and lcas
DC rear sway bar w/hardware
3 front strut tower bars
1 front lower and 1 rear lower tie bar
various engine mounts for EF DA DC
will update with more parts as i find them
mobile# 619-252-4053
clear H3 bulbs
4 OBD-1 injectors
STR cam seal red
USDM EG clock
EG clock blocker
IAT sensor
NEC ignitor
OBD-0 fan switch
DC fuel cap holder
antenna hole cover
2 muffler silencers
OEM FPR
OEM fuel rail
