AC Causing Massive water leak in car.
Old Jul 27, 2010 | 06:36 AM
DACteg's Avatar
Default AC Causing Massive water leak in car.
So, girlfriends 98 civic ex is leaking crazy water on the passenger side floor and even started to leak on drivers side. It is only when the AC is running it does this. I searched a few things but didnt come up with a solid answer.
It seams the ac coolant leaked out too, the is not that cold anymore. we Just refilled it 2 months ago, then about a month ago it leaked all the water, now its warm AC.
Any in expensive suggestions would be great
Old Jul 27, 2010 | 07:26 AM
grumblemarc's Avatar
The Grumpiest
Default Re: AC Causing Massive water leak in car.
A/C coolant?
Old Jul 27, 2010 | 08:23 AM
Former User's Avatar
The A/C drain hose on the evaporator is probably clogged with gunk, causing water condensation to spill out of the evaporator.
The hose attaches to the front bottom of the evaporator behind the glove box and drains at the bottom of the firewall below the battery.
Old Jul 27, 2010 | 09:11 AM
wiZCo's Avatar
Stouts 'n' Scotch
Seconded on the clogged evaporator drain being the culprit for the water inside the cabin.
As far as the warm air blowing, you may have a leak somewhere or a bad component in the system. I'd say to take it to get diagnosed, although most places charge $50-$70 just for a diagnosis.
Old Jul 27, 2010 | 11:04 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-c-cooling-system-2793650/
its a thread I made for an Accord but should be very similar
metalmole
Honda Civic (2001 - 2005)
Jun 18, 2014 10:30 PM
thekid2390
Jun 30, 2013 12:15 PM
No-Gi
Oct 3, 2009 06:30 AM
mandymoo2182
Jul 25, 2008 05:25 PM
gtowni3
Oct 5, 2004 06:19 PM
